Suspension need help with rear alignment
Old Apr 19, 2013 | 03:49 PM
markwrwilson's Avatar
markwrwilson
I had FSD shocks and a rear sway bar installed. Now I can't seem to get that alignment correct on the right rear tire. Can anyone help? Nothing looks bent or out of place.
R= -2.07
L= -1.55
Old Apr 19, 2013 | 05:34 PM
mbwicz's Avatar
mbwicz
Your changes should not have affected the alignment, but you probably already knew that. What was the alignment before? I thought that the factory spec for rear camber was about 2 degrees.
Mike
Old Apr 19, 2013 | 07:40 PM
markwrwilson
specs I think are -1.7 to -2.1-(or -1.2 to -1.6 depending on the source) but the adjustment is maxed out to get that.
It's a long story, but initially the struts were installed incorrectly--one front strut was not fully seated and was about 1 inch higher than the other. So I Started with front camber problems, and also the LEFT rear wheel that was out of spec.
Once I corrected the front struts, the front camber problems were solved,now the right rear is slightly out of spec!
Old Apr 20, 2013 | 04:34 AM
mbwicz's Avatar
mbwicz
If your adjustment is maxed out to try and get about 2 degrees, I reccomend that you just get them even. -1 or -1.5 is plenty of camber in the rear. If you did the free camber mod up front, you should be in that range on the front axle as well. .5 degrees of camber is not worth losing sleep over. I predict that you will be very happy if you can get 1.5 degrees on all 4 wheels.
Mike
Old Apr 20, 2013 | 07:12 AM
markwrwilson
OK, sounds sensible- thanks
emulajavi
Dec 24, 2018 09:15 AM
maestro39
Oct 27, 2015 02:38 PM
Mini'mon
Aug 26, 2015 01:02 PM
Minibeagle
Aug 13, 2015 10:00 AM
