Suspension Replacing my OEM suspension
Old Feb 26, 2013 | 09:03 PM
fourblades's Avatar
fourblades
I would like to improve my current suspension right now since my R53 has been feeling a little too stiff than usual and is now making weird noises too. What would be a good replacement, or at least what should I be searching for that would give me a better ride but not loose too much of its sports like suspension. I don't really use mine in track and but I don't want to completely loose the go-kart feel either.
Any advice or direction is greatly appreciated.
Old Feb 26, 2013 | 09:36 PM
Braminator's Avatar
Braminator
Koni sport or FSD with the stock springs IMO.
Old Feb 26, 2013 | 10:14 PM
Scavenger's Avatar
Scavenger
Bram, is that what you're running? I'm trying to tell what your wheel gap is like from that picture.
Old Feb 26, 2013 | 11:42 PM
ColinGreene's Avatar
ColinGreene
Swift springs and Bilstein sport dampers.
Mild drop and excellent handling.
Old Feb 27, 2013 | 04:47 AM
Braminator's Avatar
Braminator
I am running a completely stock sport suspension. When I do change it, I will go with the FSD shocks. I have heard nothing but good things about these shocks. I do not want to lower my MINI so that it is why I will use the stock springs. I do use a 215/45/17 tire also.
Old Feb 27, 2013 | 05:40 AM
phoxx47's Avatar
phoxx47
Way Motor Works just installed FSD's and 19mm rear sway bar plus the rubber duckie thing that tightens the torque mount. For my situation I will say that I am extremely pleased with the results. Picked up tighter handling plus a nicer more refined ride. Normally you give up one for the other. Thanks Way!
Old Feb 27, 2013 | 08:02 AM
davisflyer's Avatar
davisflyer
FSD's will increase your handling over stock and ride better. The Swift Spring/Bilstein sports setup will make your car handle phenomenally but sacrifice some ride.
Old Feb 27, 2013 | 01:23 PM
thulchatt's Avatar
thulchatt
One more for FSD's.
Got them from WMW about two months ago and could not be more pleased.
Great improvement with stock suspension.
Old Feb 27, 2013 | 10:31 PM
pgrizard's Avatar
pgrizard
I have to disagree with davis flyer. Ive had the FSDs for 1.5yr. They do not corner as well as stock after a year, they do at first. They also get a little bumpier. They are better than stock overall but i wish i had taken collins advise 2yrs ago and got the bilstiens with swift sport springs. Try to find a local mini owner with each and go for a ride.
Old Feb 28, 2013 | 08:49 PM
N Tief's Avatar
N Tief
I just put on Koni yellows with stock springs on my 03 MCS. The stock shocks were completely blown. I drove 2000 miles round trip to LA 3 days later and couldn't have been more happy with the ride. I don't do track days, at least not yet, but I do drive very aggressively on back roads. I went with the koni yellows because I will be going to a stiffer, lowering spring. Probably WMW springs when they get them back in stock. I think it would be a great idea to go for rides in minis with various suspension set ups as mentioned in the previous post.
Old Mar 1, 2013 | 05:16 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
fourblades, I suggest that you take your MCS to a good tech for a detailed inspection before throwing money at a new set-up. Your suspension should be getting softer with age and mileage, not stiffer and making noises.
Old Mar 1, 2013 | 05:55 AM
andyroo's Avatar
andyroo
I prefer Koni Yellows (Sports) to the FSDs.
Stock is awful.
Bilstein Sports + Swifts sounds like a great combo but is probably pretty stiff.
- Andrew
Old Mar 1, 2013 | 05:57 AM
DTH2CHRM's Avatar
DTH2CHRM
+1 I agree. It appears as though things are happening in the opposite order of how they normally do.
And remember fourblades....a good tech will ALWAYS take the car for a test drive. Don't let them just rely on a visual inspection.
Old Mar 6, 2013 | 07:38 PM
fourblades's Avatar
fourblades
Oh that's really good to know. Well I won't be replacing that that soon since the suspension isn't too bad but just makes weird noise when I go weird bumps.
On a side note, my sis enjoys my sporty suspension on the high way even if it does feel like it vibrates on bad paved road. Makes her fall asleep she says. I just like to sing long notes cuz my voice vibrates too.
Old Mar 6, 2013 | 07:42 PM
fourblades's Avatar
fourblades
I don't know if I want to lower the car...yet... Probably just replace the suspension if I really need to. Gonna take the advice of figuring out my suspension issue first as advice by others before spending money.
I am still debating about changing to a different size wheels than 16" to 17" or 18". I know that will affect handling as well since the tires will be lower profile. I have moved away from runflats so I admit it's already a lot smoother and quieter ride.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
silence2-38554
Nov 12, 2015 09:39 AM
blackie
Oct 2, 2015 07:41 PM
FLYM1N1
Aug 16, 2015 01:15 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
