Suspension Front subframe torque specs needed
Old Dec 21, 2012 | 08:25 PM
Juppers's Avatar
Juppers
I am in the process of replacing a bad lower control arm and swapping to powerflex bushings. I'm starting to button it all back up, and realized I don't know what The torque values on these many bolts are supposed to be. Anyone know the values for the bushing bracket, inner ball joint, sway bar end links, steering end links, and the subframe? From searches I get anywhere from 74 to 120 ft lbs for most of them, but that is largely R53 numbers.
Old Dec 22, 2012 | 10:53 AM
Juppers's Avatar
Juppers
Found the answer at another site. http://www.trackmini.com/index.php/t...ench-settings/
Old Mar 11, 2013 | 03:42 PM
50kmsec's Avatar
50kmsec
thank you for posting that site. starting the same job myself
NYXF56JCW
Nov 17, 2024 05:06 AM
Minibeagle
Aug 13, 2015 10:00 AM
minipopkart
Aug 13, 2015 05:22 AM
minipopkart
Aug 9, 2015 12:13 PM
