Suspension Well this is just weird
Old Jun 11, 2012 | 09:04 AM
Wookie's Avatar
Wookie
After installing a 22mm rear sway, set on mid-stiff, I ran a AutoX yesterday to get used to it.
Before, with the stock bar, worn Direzzas and 10lb difference in air pressure I could get the back to rotate fairly well.
Yesterday, with the 22mm bar, new Direzzas and alb air pressure difference, the back didn't want to budge at all. I could not get it to rotate on the course at all. I did feel more grip up front, but with the lack of rotation, it still just understeered at the limits.
I know new Direzzas will have more grip, but not that much...
I'll be going to full stiff next weekend to see if that makes any difference, but I was expecting a lot more rotation on the mid-setting over the stock bar.
Old Jun 12, 2012 | 07:35 AM
andyroo's Avatar
andyroo
If those were the only changes, I"m a little surprised but I bet you can get it to rotate when you get used to it and/or some more playing with tire pressure.
Also, add some camber up front and take some out in the back.
- Andrew
Old Jun 13, 2012 | 09:41 PM
Evasive's Avatar
Evasive
At mid setting my car will barely rotate with Yokohama s drives. At full stiff, it can get tail happy.
Old Jun 16, 2012 | 04:17 PM
Wookie's Avatar
Wookie
May have figured it out- Konis on near full stiff. Backed off 1/2 turn and started to wiggle today. Will back off a little more for tomorrow's runs and I think I'll be on target.
JHolland
Sep 24, 2020 08:20 AM
rt808
Sep 29, 2015 03:15 PM
Miniwaukee
Sep 29, 2015 09:22 AM
whowantstorace
Sep 27, 2015 06:16 PM
rt808
Sep 25, 2015 01:59 PM
