Suspension Stud Conversion Kit differences
Old Apr 6, 2012 | 05:43 AM
ieandro's Avatar
ieandro
I'd like to convert so after shopping ..
WayMotorWorks sells their stud conversion kit for my '02 MCS for $119, whereas Helix has a set for $49 and Outmotoring sells theres for about $59.
What is the difference between these? Should I choose one over the other?
Old Apr 6, 2012 | 06:19 AM
killerfox's Avatar
killerfox
I have the kit from Way and am very happy with it. Make sure what ever kit you get comes with lug nuts, I have seen kits that just include the studs and the lug nuts are extra.
Old Apr 6, 2012 | 08:10 AM
ieandro's Avatar
ieandro
Thanks killerfox.
Outmotoring has a similar kit with an option of colored lugs, but at nearly half the price. I don't recall Aaron to sell products that aren't MINI-worthy. Even Helix's products are sworn by so I wonder what it is that gives such a huge price difference.
Old Apr 6, 2012 | 08:16 AM
ieandro's Avatar
ieandro
Seems like i misssed this .. Outmotoring = Gorilla studs
https://www.northamericanmotoring.co...onversion.html
Old Apr 6, 2012 | 11:38 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The bolt grade and quality of material is the difference.
Old Apr 10, 2012 | 10:34 AM
srtoad4's Avatar
srtoad4
What length lug studs do I need to get if I want to put a 10mm spacer in the rear, and a 5mm spacer up front? Will extended lug nuts also work with the 12x1.5 lug studs?
Old Apr 15, 2012 | 11:44 AM
Evasive's Avatar
Evasive
The studs Way sells are long enough for both a 5mm and 10mm spacer. You won't be able to use a close ended nut as the studs would likely be still be a bit too long.
Alkaidovich
Jan 30, 2021 01:35 AM
MINI VINI
Oct 13, 2015 08:57 AM
AZN Optics
Aug 16, 2015 11:52 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
