Suspension NM lowering springs = good stuff
  #151
Old 10-14-2013, 06:40 PM
PureWorks's Avatar
PureWorks
PureWorks is offline
Wow...a lot of great information over a number of years as I read the entire thread....I have. CMS4, just bought used, not sure if sport suspension comes with the "S" model? The car also came with "20" TSW wheels. I was thinking of Eibach springs, which I have put on probably 10 of my previous cars.
My questions are: is there enough clearance...does a sport suspension come with the "S" model? If not should I just go for the Megan coil overs? Thanks!
  #152
Old 10-14-2013, 09:22 PM
youthanasia's Avatar
youthanasia
youthanasia is offline
Sport suspension is an option. Easiest way to tell is ask your dealership, they should know by the VIN.
  #153
Old 10-15-2013, 07:35 PM
PureWorks's Avatar
PureWorks
Thanks! Found out I don't have the OEM sport suspension and also that the Coilovers will not work on the All4....,looks like I'll be calling on my old friend Eibach to help make the suspension a little more aggressive....
  #154
Old 10-16-2013, 12:44 AM
detours's Avatar
detours
detours is offline
Coilovers should work just fine on the All4. Both Megans and KW V3.
  #155
Old 04-22-2014, 05:50 PM
molala's Avatar
molala
molala is offline
New owner and to Mini! I see they dont have specific COs for All 4 besides the KW v3. Anyone got the Megan COs on their All 4? I know they are for FWD but bit shaky to try on All 4. Thx in adv
  #156
Old 04-22-2014, 06:06 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
We've installed the Megans on an ALL 4 with no issues, and had 2 customers get them from us and put on ALL4s with no issue so I wouldn't worry about them not working. The car we did drove great and looked awesome.
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
  #157
Old 04-22-2014, 06:48 PM
molala's Avatar
molala
molala is offline
Install no problem on the All 4? Ride quality ok although is for fwd? Like will the ride quality be very bad and bouncy etc
  #158
Old 06-08-2014, 06:23 PM
CPap's Avatar
CPap
CPap is offline
I ended up going with NM. I also installed the Bilsteins in the rear to eliminate any possible bounce some people were reporting. I installed the WMW sway bar and Hotchkis control arms at the same time. All in all, I am very happy. Handles amazingly now. I was a little worried the oem front shocks wouldn't keep up with the rear billies ... But they are both playing well together. It was a tough decision going with springs instead if coilovers but didn't want to deal with the CO's corroding due to the northeast winters. Every set I've owned went to pot after a salty winter.
Attached Thumbnails NM lowering springs = good stuff-image-288789450.jpg   NM lowering springs = good stuff-image-3192627974.jpg
  #159
Old 06-08-2014, 08:14 PM
molala's Avatar
molala
molala is offline
Nice! So only rear Bilstein? You hv OEM Sport Suspension? Yea since not much CO option for All 4, the spring & shock combo is a pretty good choice
  #160
Old 06-09-2014, 04:09 AM
CPap's Avatar
CPap
CPap is offline
Yes, the Bilsteins are in the rear only and stock oem (not sport) in the front. I haven't noticed any odd characteristics between the two. More driving will tell the tale.
  #161
Old 06-09-2014, 10:17 AM
molala's Avatar
molala
molala is offline
Ok, never seen or heard ppl just do either just front or rear only shocks! Hope they will be ok and work out for you. I wish All 4 has more suspension combo and COs available
  #162
Old 06-09-2014, 10:52 AM
CPap's Avatar
CPap
CPap is offline
Agreed, generally, I would never contemplate this scenario. I have been talking with NM and they thought it would be a good set-up as well. I didn't want to deal the potential bounciness of the rear. I do have the luxury of just swapping the fronts at anytime if I feel its not working out. I perform my own work and the fronts only take about an hour to do. So far, so good though.
One thing I do notice with front and rear springs is the ride is certainly a little stiffer than stock. I was expecting them to have the same cush oem ride quality people were reporting about. Its not overly stiff but certainly noticeable...in a good way.
  #163
Old 06-09-2014, 09:03 PM
PureWorks's Avatar
PureWorks
I put HR springs on mine, kept the non sport shocks on my All4S, which came with 20"...I also added the Way rear sway and it handles great....I also have a front strut.....probably need some links someday....and I'm sure shocks.....but all in all....I'm jazzed...
  #164
Old 10-15-2014, 03:44 PM
kaikai114's Avatar
kaikai114
kaikai114 is offline
I'm deciding between NM & H&R...
What's the difference the NM Springs & H&R Springs? or at least the "spring rates"
  #165
Old 10-16-2014, 10:49 AM
SmithWerks's Avatar
SmithWerks
SmithWerks is offline
comparing published Spring Rates for a progressive rate spring isn't an entirely accurate comparison as different manufacturers may have different ways of measurement.
ie. Is the stated rate the starting # or max/full compression number?
The actual 'rate/increase' of progression is also very important to ride quality.
ie. The first 1/2" of brand A is very soft, but then rises to a higher rate very sharply. say, brand B is relatively soft for 1.5" & then dramatically increases.
-there will be a difference in ride quality on choppy roads where the initial 2" of spring travel is being used.
Spring Rates are often not shared by manufactures for these reasons. Rates on Liner spring are entirely different. These however are progressive.
I've has the NM-E springs with 19" NM-E wheels on my ALL4 for aprox 25K & yes, they are stiffer than stock. Yes, you may bottom out(rears) on big hits. Yes, they are more responsive. No they are not horrible & crashing. Yes you will notice the difference slightly.
They are paired with my Factory Sport Suspension Shocks. The NM-E springs are aprox 3/4" lower than the already lowered factory sport springs.
Im pretty sure Neuspped doesn't coil their own springs, H&R used to for them many years back.
Having had lowered suspensions on every car Ive owned for over 20 yrs, I will say that H&R does IMO make the nicest progressive springs. They have truly mastered the 'rate of progression'.
How do they compare side by side the the NM-E? I haven't a clue. probably very very close.
  #166
Old 10-16-2014, 11:01 AM
kaikai114's Avatar
kaikai114
What made u choose NM over the H&R when u bought the springs?
Kevin
  #167
Old 04-02-2015, 06:22 AM
teinesina's Avatar
teinesina
teinesina is offline
Just got the NM springs! awesome ride!
I am looking into getting adjustable control arms since I couldnt get camber on the rear in past -3 degrees.
I noticed that the NM adjustable rear sway bar links are recommended for lowered cars with aftermarket sway bars (I have the NM RSB too) and was wondering what these accomplish when the car is lowered and if anyone out there with nm springs and sway bar also put these on?
  #168
Old 04-04-2015, 08:17 PM
monkiboy's Avatar
monkiboy
monkiboy is offline
Good to hear you like your ride teinesina! Mine arrived a few weeks ago but still haven't gotten around to installing them yet, =).
How do you like the ride quality so far? Show us some pics!
  #169
Old 04-04-2015, 08:26 PM
teinesina's Avatar
teinesina
Oh I freakin love it! It absolutely wants to devour turns! I love the generally firm feel too. There's something about that subtle feel over road bumps and what not that just gives me goosebumps Slowing down for railroad tracks and not just plowing blindly over stuff is just one more way I look after my car now and I love taking looking after him!
Attached Thumbnails NM lowering springs = good stuff-img_1008.jpg   NM lowering springs = good stuff-img_1014.jpg
  #170
Old 04-16-2015, 10:06 PM
monkiboy's Avatar
monkiboy
monkiboy is offline
Just lowered my countryman with NM springs with stock sport suspension. Loving it so far!
Attached Thumbnails NM lowering springs = good stuff-img_20150415_171656.jpg   NM lowering springs = good stuff-img_20150415_121527.jpg
  #171
Old 04-23-2015, 04:39 AM
Jays_CM's Avatar
Jays_CM
Jays_CM is offline
Does anyone have any suggestions for cutting the factory bump stops or not when istalling lowering springs?
NM says to cut off to the first rib.
  #172
Old 09-30-2015, 12:55 PM
misterb's Avatar
misterb
misterb is offline
Just recently sold my 2012 Countryman S and after 3 years with the NM springs, I ended up NOT LIKING THE RIDE. With just me in the car, the ride was ok but it did not handle small bumps or road imperfections well, especially in turns... the car would bounce around from side to side. Under load (with passengers in the car) the ride was VERY bouncy and my wife and 16 old hated riding in it. The only plus was that only perfect mountain roads, it handled way better than stock - way less body roll.
  #173
Old 04-01-2019, 10:16 AM
weaverpsu's Avatar
weaverpsu
weaverpsu is offline
Anyone else with feedback on NM Springs? I'm looking to have them installed with rear sway bar and I'm hoping for a drastic change to handling and looks. Haven't purchased either yet. I'm told the springs are progressive and therefore provide a better ride as well as being stiffer around corners with less body roll. Obviously the sway bar will do this as well. I honestly don't mind a stiff ride. My R53 drove like a go-kart and I loved it. What I don't want is a bouncy ride like some have mentioned. The car in stock form has bouncing issues. More than any car I've ever had. It can be alarming and is one of the main reasons I want to upgrade the suspension. Don't have money for shocks though.
  #174
Old 06-03-2019, 06:15 PM
Junior 2.0's Avatar
Junior 2.0
Junior 2.0 is offline
I just installed the NM rear sway bar in my wife's 2016 R60 and set it to the mid setting. It took away a lot of the bounce and roll that it had before. I'm also looking at doing the coilovers as well, but so far, she's happy with the way it is driving now.
  #175
Old 08-06-2019, 02:10 PM
weaverpsu's Avatar
weaverpsu
Thanks. I saw a bunch of people say to put it on stiffest setting and then months later started seeing a couple people say to start with mid-setting. Interesting. I bought sway bar but no springs yet.
jeremy_reyes94
09-06-2019 07:53 AM
melscoop
03-30-2016 06:56 PM
yukinoinu
15
08-24-2015 09:20 AM
Emnotek
08-13-2015 05:47 PM
OutMotoring
08-06-2015 09:32 AM
Quick Reply: Suspension NM lowering springs = good stuff
