Suspension My hybrid suspension
So, had some issues with the front FSDs and ended buying two yellows.
Here is my current setup:
2 yellows front (50% setting I believe), 2 FSDs rear.
Tein H-tech all around (0.5 drop).
19 sway rear on the middle setting.
Any potential issues? It seems to ride great. I know that lowering springs and FSD are a no-no, but besides that...
I would think things would be ok for putting around, but if you got onto a twisty road and started to push the car you might run into unpredictable handling characteristics.
What would make it unpredictable?
It might upset the balance of the car. I would liken it to running different brands/models of tires on each axle. Or running progressive rate springs mixed with linear rate springs.
The FSDs are just really soft, so it will understeer a bit with them in the rear. No real issues, but the rear might feel a bit wallowly and sloppy compared to the front. Probably not too bad.
I run my yellows around 1/4 turn from full soft with Tein H-tech. A little soft compared to others but I like it a lot. My roads are crap though.
- Andrew
- Andrew
vulkandino
Oct 31, 2015 08:29 PM
GAT
Oct 4, 2015 07:27 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Emnotek
Sep 29, 2015 07:37 AM
