Suspension ST Coilovers installed, some thoughts and pictures
Old Feb 14, 2012 | 12:52 PM
  #126
MINIGEZR's Avatar
MINIGEZR
Originally Posted by localbrew
so you did raise it up a bit then? Post some new pics when you can.
I need to get some new pictures, but the ride height is pretty much the same. I just tried to even out all 4 corners.
Old Feb 14, 2012 | 12:59 PM
  #127
MINIGEZR's Avatar
MINIGEZR
I need to take some new pictures! I only made a small adjustment to even out all 4 corners-1/2 turn on passenger rear. I'll post some pics later this week
Old Feb 14, 2012 | 01:37 PM
  #128
simplybao's Avatar
simplybao
Originally Posted by MINIGEZR
Hey localbrew, funny thing I was just going to post when I saw your post. I have the exact same thing-knocking/clunk sound happening on mine when the car sits. Happens in forward or reverse just once and then its fine. I feel its coming from my front drivers side and I'm not happy! Strange thing is it just started doing this after about 1 month with no issues.
To Kris @ suspension source, any thoughts??
Mine makes noises like that too. I just don't pay attention to it. But then again, I don't know if it was making those same noises before the suspension. I just ignore it. It doesn't bother me. I've had enough lowered cars to know that sometimes you just have noises.
The noises do go away you've driven the car for a bit. Also, I have the dreaded vibration issues too. Again, I don't care. I know that it happens to some of us that are lowered. I'll continue to drive it like I stole it and if I breaks, then I'll figure something out.
Old Feb 14, 2012 | 01:39 PM
  #129
TheSuspensionSource's Avatar
TheSuspensionSource
Hmmm. Nothing comes to mind. I did however call over to ST and talked to Adam. He would like for the both of you to email him about this problem your having
adam.tormey@kwautomotive.com
Old Feb 14, 2012 | 01:49 PM
  #130
MINIGEZR's Avatar
MINIGEZR
No problem Kris I will shoot him an email.
Old Feb 14, 2012 | 01:51 PM
  #131
simplybao's Avatar
simplybao
Let know how it goes with him. I'm curious to know. For me, it's a small "clunk" like noise. It's almost like something is moving. The car seems to drive ok though. I have about 4K miles on my setup.
  #132
localbrew's Avatar
localbrew
Thanks Kris, I'll send him an email now, I have taken the strut back out twice re-torqued everything to specs and it still does it. It's the exact same sound as MINIGEZR has described. The sounds have more caused me to question safety, which is why I have pulled it out twice to check.
Old Feb 14, 2012 | 01:53 PM
  #133
TheSuspensionSource
Keep me up to date on what comes about this. I would like to know for future reference.
Old Feb 14, 2012 | 02:01 PM
  #134
simplybao's Avatar
simplybao
Kris,
I emailed him too. We'll see what he says.
Old Feb 14, 2012 | 02:08 PM
  #135
MINIGEZR's Avatar
MINIGEZR
Simplybao; I never had any noises prior to installing the ST's. This is definitely something new. Can you explain/elaborate a little more on your vibration issues. I think I may have a very slight vibration under acceleration? I understand that when you make changes like this the car feel will change. I would just lke to keep it as near perfect as possible!
Old Feb 14, 2012 | 02:12 PM
  #136
MINIGEZR's Avatar
MINIGEZR
Safety was my concern too and had everything checked to be sure. I would hate to do any damage. Lets see what Adam has to say.
Old Feb 14, 2012 | 02:23 PM
  #137
simplybao's Avatar
simplybao
The vibration I'm talking about is at low RPM. It's well documented in the suspension forums. Just do a search on vibration after lowering. There is a VERY long thread about it. In short, it's nothing to worry about. It has something to do with the angle of the axles. Don't quote me on that. Find that thread and you'll see what I'm talking about.
Adam replied already. BUT, he sent a PDF and I don't have the ability to modify the PDF.
Old Feb 14, 2012 | 02:28 PM
  #138
MINIGEZR's Avatar
MINIGEZR
Thanks Bao.
Adam replied to me too. Now I have to get that info and measurements for him! You could print and fax it back to him.
Old Feb 14, 2012 | 02:38 PM
  #139
TheSuspensionSource
Another reason why I love carrying ST products. Their tech/customer service is really good.
Old Feb 14, 2012 | 06:51 PM
  #140
Digitys's Avatar
Digitys
The vibration at lower RPM's is due to the change in drivetrain, when you lower the car, you change the angle of the axel or whatever drives in the wheels in a front wheel drive. That causes the vibration.
I have however noticed with my ST's, that at first, I had the spring lined up when i put the set up in but when i adjusted the ride, the spring shifted out of the top perch. I think that was causing a strange noises at first when i was at slow speeds. I fixed it now and things are good.
Old Feb 18, 2012 | 10:02 AM
  #141
MINIGEZR's Avatar
MINIGEZR
I'll check that out, thanks for the suggestion.
Old Feb 27, 2012 | 08:01 AM
  #142
chilimini81's Avatar
chilimini81
Do you re-use the stock front upper spring perches with these? The reason I'm asking is because I was looking at the Vorshlag front camber plates, and you have to choose which upper spring perch size is needed. I'm assuming stock size.
...oh and also do you re-use the oem bumpstops? If not, what are the shaft diameters?
Old Feb 27, 2012 | 08:34 AM
  #143
simplybao's Avatar
simplybao
You know, I can't recall which parts I used. I'm sorry. I do know that the factory bumpstops aren't used. There are new ones that come with the kit.
Old Feb 27, 2012 | 05:21 PM
  #144
localbrew's Avatar
localbrew
Minigezr, Simplybao - I just returned from work and haven't had time to get Adam my stats on the suspension. Have either of you been able to resolve it?
Old Feb 27, 2012 | 05:23 PM
  #145
simplybao's Avatar
simplybao
No, I travel just about 5 days a week for work and the weekends have been hectic. I haven't had a chance to. Mine doesn't always make the sound, either that or I just don't think about it.
Old Feb 28, 2012 | 05:26 PM
  #146
MINIGEZR's Avatar
MINIGEZR
I emailed Adam yesterday asking if he had heard from you guys/updates as I haven't had the time to get the measurements. Hopefully this week I can find time. I'll keep you both posted here if I forward him the info. I really would like to resolve this knock!
Old Mar 11, 2012 | 03:15 PM
  #147
dannyhavok's Avatar
dannyhavok
Well, I installed these last Monday. Or rather, I paid someone competent to install them.
I started a thread, but it received no attention, and this is the most active ST coils thread, so I figured I would share my update here. It has been about 225km on the new system so far, and it's starting to settle a bit. They handle really great, it feels surefooted in the corners, little to no body roll. It is a firmer ride than the stock non-sport suspension, but it feels compliant and not jarring or rough. I think it's a great compromise between comfort and handling.
I haven't had the alignment done yet, and the tech wanted to wait to install my H-Sport control arms.
I purchased 5mm spacers but they were not needed. My tire/wheel setup is 205/50/16 on 16x7 et40 Konig Feathers. Unfortunately they installed the spacers anyway, otherwise I would have sold them cheap. I did not need the longer bolts (because I already had aftermarket bolts.) so I DO have a set of 8 longer bolts from H&R that I will sell cheap to anyone who needs them and PM's me. Still in the bags.
Anyway here are some photos of my car showing the gap and the rear strut to see where it's adjusted to. The tech said he set it up to be "24 inches all around," which I assume means from ground to fender.
("Tall" coffee cup. I will be cutting off that chin piece. It scrapes.)
Thanks again to TheSuspensionSource for hooking me up with these. Great service, great product.
Old Mar 11, 2012 | 08:08 PM
  #148
Digitys's Avatar
Digitys
A few weeks after mine were installed, I think I have finally found the right ride height or at least until winter really goes away. Love the coilovers so far. Below are some pics
Old Mar 19, 2012 | 06:09 AM
  #149
bhegg's Avatar
bhegg
Good info in this thread! I'm about to install my ST coilovers. For a 1.2" drop, will I need camber plates and LCAs for proper camber adjustment suited for occasional track days/autocross ??? I know about the free camber mod, but I doubt that would be enough.
Thanks in advance.
Old Apr 7, 2012 | 10:06 AM
  #150
smoke05S's Avatar
smoke05S
Beautiful car Digitys! I have the same tires. Are those 215's? Any rubbing issues?
