Suspension ??? SWIFT replacement springs for Koni 1150-5079 Coilovers
Old Oct 11, 2010 | 01:05 PM
Dave.O's Avatar
Dave.O
Does anyknow what the SWIFT replacement coilover spring sizes are to replace my worn out Koni Threaded Suspension Coilover springs?
I have an 05 MCS.
I have the Koni 1150-5079 Coilovers. They are the same set you can purchase on TireRack & Outmotoring.
http://www.outmotoring.com/mini-coop...coilovers.html
Mini 02-06 Cooper, Cooper S (production date on or after 3/02) - 1150 Threaded Suspension kit\
http://www.koni-na.com/cat_search.cf...=30&submit.y=4
Old Oct 11, 2010 | 01:22 PM
KC Jr 54's Avatar
KC Jr 54
There is not a direct swap of swift springs for the Konis.
You would have to get different spring top-hats and then figure out what spring rate and length spring you would need.
I would suggest you call Helix, and speak with him about your situation, as it seems like he would be the one doing your wrench work.
Old Oct 11, 2010 | 05:45 PM
Dave.O's Avatar
Dave.O
Yeah I am going to talk to Eric (owner of Helix) Wed but I was wondering if anyone knew what swift spings would be used for just the rear koni coilovers.
I may just dump the effen Konis pull the trigger on some new WMW KW2.
Old Oct 12, 2010 | 08:04 AM
andyroo's Avatar
andyroo
You can measure the ID of the lower spring perch and go from there...probably 60mm but could be 2.5 inch. Then for a length you will probably want 7 inch. You may also want helper springs. As KC Jr said, you will probably also need a new upper spring perch. Best to take it to a shop that knows what they are doing.
It's certainly doable. And keep us posted if you go through with it. How do you like those coilovers?
- Andrew
Old Oct 13, 2010 | 09:54 AM
Dave.O's Avatar
Dave.O
Overall I really have liked the Koni C/O's but the rear spring issue is a PITA to deal with now. The Konis have been on for over 2 years without any issues.
Teh
Aug 22, 2022 04:37 AM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
blackie
Aug 25, 2015 09:08 PM
Emnotek
Aug 13, 2015 05:47 PM
OutMotoring
Aug 6, 2015 09:32 AM
