Suspension Control arm and lowering spring install questions
Old Jun 24, 2010 | 10:25 AM
johnbarleycorn's Avatar
johnbarleycorn
I have 2 fairly quick questions wrt installing lowering springs and adjustable control arms. On the lowering springs when you are putting the strut back together how far down should you tighten the nut that holds everything together? With the control arm does anyone have any pointers on removing the upper bolt? I have bent the heat shield out of the way and can access the nut without issue but getting to the bolt head is a pita and i cant get my socket wrench in there to hold it because the gas tank is in the way. Any help or pointers are appreciated.
B
Old Jun 24, 2010 | 12:55 PM
tvrgeek's Avatar
tvrgeek
The nyt shoud bottom out and reach the torque spec. 45 Ft lbs for my HD's.
On the bars. Yea. So I have been told you "just bend the shield a little" and use "several extensions and u-joints" Enough I am going to have Mach V do mine.
Old Jun 24, 2010 | 09:53 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I use a mid lenght socket to get to the inner lower control arm bolts, that or a standard socket and 1inch extension.
Old Jun 25, 2010 | 02:08 PM
johnbarleycorn
I didnt have a 1" extension but I was able to get it after purchasing using a u joint. I can already tell that little guy is going to be my new best friend!
melscoop
Mar 30, 2016 06:56 PM
maestro39
Oct 27, 2015 02:38 PM
Emnotek
Aug 13, 2015 05:47 PM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
