Suspension Replacing rear track bars
Old May 17, 2010 | 03:11 PM
tvrgeek's Avatar
tvrgeek
While taking advantage of the hospitality of the new Mini dealer in Reisterstown, thank you guys, I was able to take a good look under a Mini from far enough away I could actually focus on it. It looks like the inner bolts for the rear track rods are impossible to get to. Is there a trick? I am planning on a set of the adjustable bars from TSW to de-camber the rear. ( R56)
Rear shocks look pretty easy. All from underneath. Fronts look like about every other strut. I can see why the front arm rear bushings are a pain, and both sway bars are totally up in there.
Again, thanks for the open-house. Very helpful to see a car in the air in good light. Surprised at how much anti-dive is in the front. On the flip side, that may be part of why it unloads so far under acceleration.
Old May 18, 2010 | 03:10 PM
tvrgeek's Avatar
tvrgeek
No hints? I found a PDF from one of the bar makers. " just bend the heat shield a little". OK, that would be AFTER dropping the exhaust, and does it mean dropping the rear subframe? I just can't see how one could get a wrench on the top inner bolts or have room top back them out.
Old May 18, 2010 | 04:55 PM
ron-s mini's Avatar
ron-s mini
For the lower bars it is tight but other than "pushin and shovin" on the heat shield it is doable without removing anything.
I would talk to Jeff at TSW for details.
Old May 18, 2010 | 05:01 PM
tvrgeek's Avatar
tvrgeek
Good idea.
squawSkiBum
Oct 2, 2015 09:21 AM
nomar116
Aug 10, 2015 11:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
