Suspension lowering my MINI, Help Please.
Old Jan 4, 2010 | 10:04 PM
Thirsty Fire's Avatar
Thirsty Fire
I have MCS 07 and I'll install
H&R Lowering Springs
Sway Bar
Front and Rear Sway Links
JCW Strut Bar
where can I find the tightening torque for bolts I've searched for a PDF Service Manual but no luck.
Old Jan 21, 2010 | 03:34 PM
Thirsty Fire
Update:
I will take my car soon to a shop to install everything including the lightened Crank Pulley, unfortunately MINI is not a well known car in my country so its nearly impossible to find a shop that worked on one before.
What exactly I can do to help them?
Old Jan 21, 2010 | 03:43 PM
BSUCardinalfan's Avatar
BSUCardinalfan
other than the crank pulley (which I personally think doesn't produce enough improvement to justify the work), the suspension stuff is standard and if they've worked on pretty much any car with struts they'll be able to figure it out.
Old Jan 21, 2010 | 03:51 PM
Thirsty Fire
My concern is the tightening torque and they don't have a service manual for MINI
Old Jan 21, 2010 | 07:27 PM
bigsmittyJAS's Avatar
bigsmittyJAS
If you can't find the official numbers, go to the SAE specification. I would assume that Mini is using grade 12.9 metric bolts for suspension components. Use the column on the far right:
http://www.engineershandbook.com/Tables/torque1.htm
Old Jan 21, 2010 | 08:04 PM
Oxybluecoop's Avatar
Oxybluecoop
Sway Bar
JCW Strut Bar
Request.pdf
http://www.minigenuineparts.co.uk/MI...structions.PDF
Old Jan 21, 2010 | 11:01 PM
Thirsty Fire
Thanks guys that's really helpful.
Old Jan 22, 2010 | 02:44 AM
countryboyshane's Avatar
countryboyshane
Go to the M7 website then go to "install". If you look at the coilover guide for the R56 he's listed many torque numbers.
Old Jan 24, 2010 | 12:18 AM
Thirsty Fire
Thank again, I took my car to the shop yesterday I will take back tomorrow.
Do you think I need to Install anything else like control arms?
Old Jan 24, 2010 | 02:51 AM
tinyz1397's Avatar
tinyz1397
reply
the bently manual (sorry cant spell)! you can order it from helix13.com they are a great company and they can help with everything great company
Old Jan 30, 2010 | 10:05 AM
Thirsty Fire
Now everything is installed, I took the car today finally 6 days without my MINI. Anyway I hear noises in the front when I hit any bump, is that normal?
Old Feb 2, 2010 | 07:34 AM
Gilboyto's Avatar
Gilboyto
No, this isnt normal! lol. They may not have properly torqued/tightened the strut bolts that come thru into the engine bay. My recommendation is to find a shop/buddy that has an air impact wrench, get the socket on there and blast each one for a second or two to make sure they are tight. Seems like people have had the most problems with that area...
Old Feb 2, 2010 | 08:18 AM
DDoggJCW's Avatar
DDoggJCW
Gilboyto - agreed. I just finished installing H&R springs on my car (w/ stock shocks and struts). An impact wrench is your savior.
Thirsty Fire - what kind of noises are you hearing??? Clunking? Tapping? Vibration?
Old Feb 2, 2010 | 12:18 PM
Thirsty Fire
It is like two metal are hitting each other in both sides left and right it depends on which tire take the bump.
What about the links length? do you think it will cause this kind of sound?
Old Feb 2, 2010 | 09:44 PM
etalj's Avatar
etalj
The bolts that come through to the engine bay are only meant to be torqued to around 25Nm aren't they?
Old Feb 2, 2010 | 09:49 PM
Oxybluecoop
correct
Old Feb 2, 2010 | 10:22 PM
etalj's Avatar
etalj
Old Feb 3, 2010 | 10:06 AM
Thirsty Fire
guys you are right I torqued the bolts now everything is fine.
thanx
jeremy_reyes94
Sep 6, 2019 07:53 AM
flredmini
Apr 5, 2016 06:21 AM
nomar116
Aug 12, 2015 05:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
