Suspension Question about Whiteline rear swaybar
Old Jan 30, 2010 | 11:37 PM
smoke05S's Avatar
smoke05S
Does anyone have a Whitline 20mm rear swaybar on their 09 JCW? Their documentation states it only fits the 02 thru 04. I was under the impression all mini's (first or second generation) all use the same swaybars.
Old Jan 31, 2010 | 01:44 AM
etalj's Avatar
etalj
I am. They all fit fine. Same design from 02-09
Old Feb 1, 2010 | 04:30 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes it will fit, I think I actually have one on the shelf, but I really prefer the Hsport swaybar for your car.
Old Feb 1, 2010 | 04:48 PM
Porthos's Avatar
Porthos
Link to sway bar?
Old Feb 3, 2010 | 11:26 PM
smoke05S's Avatar
smoke05S
Isn't that H-sport hollow? I have sport suspension so my current bar is solid 18mm. Wouldn't the hollow 19mm be a step backward in stiffness? I guess it would help the unsprung weight a little (but the lever arms are so short on the rear bar so this is only ounces we are talking about). My plan is to put the 20mm on the JCW and the 09 JCW bar on the 05 MCS
Porthos, 2 questions for you (different topics). Are your LED side markers plug and play or did you add load resistors? and 2. With the shorty antenna when you are listening to AM and go under power lines do you only get AC hum or can you still hear the station?
W0TM8
Dec 19, 2019 07:50 AM
jeffbeckhudd
Aug 29, 2015 09:11 PM
Bennyboy
Aug 18, 2015 07:28 AM
Minibeagle
Aug 13, 2015 10:00 AM
tag1260
Aug 5, 2015 04:27 AM
