Suspension Replace rear camber link with NM springs?
I installed my NM springs and did not replace the rear camber links. Not sure what the rear camber is now....looks good, but I'm not sure if I should worry about tire wear.....what did most of you do?
I dunno about that. The rear camber gain is quite high, and the NM springs offer quite a bit of drop (1.2").
I would get the control arms just to make the handling better, simply because you shouldn't really have more camber on the rear than on the front on a MCS
I recommend getting a set of Hsport rear camber links. If you go get an alignment you'll find you have too much camber. The stock adjustment isn't enough. But I do think it's a good idea to let the springs settle before the alignment.
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
