Suspension VMaxx question
Old May 13, 2009 | 08:43 PM
  #26
Mr. Incredible's Avatar
Mr. Incredible
Originally Posted by MUShadd
because it was sitting there on my bed, next to my laptop... I'm showing of my sheets too, no mention of those?
Mr. Incredible, I have heard these can bit a bit noisy, and is normal, but not sure how noisy theyre supposed to be, or whats too much. i'll try to post up my thoughts/impressions when i finally find a weekend to put mine on.
Thanks for posting up the pics. I just got some 5mm spacers so that I can lower it some more... Does anyone know if I need longer bolts with 5mm's?
Old May 14, 2009 | 03:16 PM
  #27
MUShadd's Avatar
MUShadd
yes, it is recommended. TSW and AutoXcooper sale nice stud kits. I'm running them on mine.
Old May 14, 2009 | 04:37 PM
  #28
4Boogie's Avatar
4Boogie
all throttle no bottle
^^^yep TSW makes good studs.
MUShadd- Think about waiting a few days after you install you coils to get an alignment. You might want to make adjustments once you drive the car a bit which will throw you alignment off.
Old May 15, 2009 | 07:47 PM
  #29
Mr. Incredible
alright so i put the 5mm spacers on and there is literally less than an 18g wire's worth of clearance between the tire and the locking rings on the coilover... I'm about $85 deep into getting the coils to fit with these wheels and I don't even want to keep them very long, i'm sort of annoyed. I'm tempted to get some new wheels that will fit better without the spacers. any suggestions anyone?
Old May 16, 2009 | 11:30 AM
  #30
Mr. Incredible
Well, here we are with the 5mm spacers... obviously not enough!
Old May 16, 2009 | 04:42 PM
  #31
4Boogie's Avatar
4Boogie
You're gonna need 8mm, I wouldnt go 10. I got my custom wheel spacers at www.wheeladapter.com they were $280 shipped with the correct centerbore. You should go ahead and change your wheels if thats what you're planning to do so you're not waisting time and money
Old May 19, 2009 | 05:58 PM
  #32
DjR53's Avatar
DjR53
is anyone using camber plates with the vmaxx/
Old Jun 5, 2009 | 07:57 AM
  #33
MUShadd's Avatar
MUShadd
Mr. Incredible, that is weird. I can't tell is...is that the front or rear? (looks like the front)...did you use the supplied spacers in the rear? I have 215/45 tires and 5mm spacers..I can fit a finger between my tire and coil. what is your wheel offset?
Old Jun 5, 2009 | 03:20 PM
  #34
Mr. Incredible
Thats the front... I didn't get any spacers with them, was I supposed to? I've emailed Stratmosphere several times in the past with no response. Not sure on the offset but they are OEM S-Lites with 205/45s
Old Jun 6, 2009 | 01:41 AM
  #35
minimyke's Avatar
minimyke
Im running IE race plates on VMAXX with Megan front springs, what question did you have about camber plates?
Old Jun 7, 2009 | 04:10 PM
  #36
MUShadd's Avatar
MUShadd
spacers came for the rear struts. mine were taped to it in a little baggy. and goodluck getting them to reply to emails.....they are terrible. you are better off calling.
but since those are your fronts, id either go to 8mm spacers or swap wheels and/or tires.
Old Jun 21, 2009 | 09:20 PM
  #37
thebillsman's Avatar
thebillsman
ive got 18x7.5s, am i going to need spacers with a set of vmaxx's?
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
twriter
Oct 2, 2015 03:14 PM
Carwash
Sep 15, 2015 02:02 AM
marc0011
Sep 10, 2015 10:04 PM
