Suspension Bought some coilovers, have some questions
Old 03-03-2009, 04:10 AM
oxtox's Avatar
oxtox
oxtox is offline
Originally Posted by iwashmycar
are they harder to install than springs? if not then i suggest just looking at a DIY thread...
yes, harder than just springs. and a good idea https://www.northamericanmotoring.co...-feedback.html
Originally Posted by Dr Obnxs
First time you do this, it takes about half a day. After you do it a few times, you'll get it down to about an hour and a half for all four corners.
Matt
but it is a fun (at times frustrating) and very informative half day
  #27
Old 03-03-2009, 01:44 PM
pimpedout97x's Avatar
pimpedout97x
pimpedout97x is offline
this is the thing i was talking about that i thought would hit the wheel when i lowered it.
  #28
Old 03-03-2009, 01:46 PM
pimpedout97x
Originally Posted by oxtox
and just to clarify, this lower et = moves the wheel towards the outside
late edit:
fyi my 215/45-17 on 17x7 et 37 rub the rear arch at 1.5 inch drop (there was no rub with the stock 17x7 et 48 with 5mm spacer)..it can get tight back there!
215/45/17 is taller than my 215/35/18
and my 18s are only .5" wider as well
  #29
Old 03-03-2009, 01:47 PM
Dr Obnxs's Avatar
Dr Obnxs
Dr Obnxs is offline
That's the lower spring perch and it'd position relatve to the wheel is fixed. It also goes away if you go to different struts.
Matt
  #30
Old 03-03-2009, 03:59 PM
pimpedout97x
nice
  #31
Old 03-03-2009, 04:10 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Rally@StanceDesign is offline
It's a fixed position on struts, but if you're talking about coilovers the lower perch will move as you spin the coilovers down. The position is then fixed wherever you set the coilover perch.
Granted, the lower perch of the Vmaxx's is much smaller than that so I don't think you should have any clearance issues. It's something to keep an eye on. If you want to go lower but it will hit your tire....buy some spacers and longer lugs.
  #32
Old 03-03-2009, 05:14 PM
pimpedout97x
nice
Teh
08-22-2022 04:37 AM
Ryephile
Suspension
113
02-09-2020 03:43 PM
Hippiehobbit267
12-03-2019 04:22 PM
cjsdad
08-11-2015 08:46 AM
nomar116
08-10-2015 11:24 PM
Quick Reply: Suspension Bought some coilovers, have some questions
