Suspension M7 Strut Bar!
Old Aug 22, 2008 | 09:52 AM
  #26
MINICDN's Avatar
MINICDN
Originally Posted by dtsoccer6
Thanks! yeah, i removed the heat shield of the ALTA CAI because it was rattling and being a real big pain. So, I custom fit the hoses and now it freed up room to move it how I wanted. Just as an FYI, that is the OEM bracket model.
I like the cleaner look of the install without the CAI heatshield. Can you explain what you meant by the "OEM bracket model"?
This whole thread has been very informative as you guys have been posting some great details and pics of the mods that I have planned for the future.
Also, I read another post recently about the M7 heatshield and that they had made a mod to prevent it from giving you any rub on the inside of the bonnet...maybe wise to contact M7 on that for details.
I look forward to reading more here on these topics.
Old Aug 22, 2008 | 11:05 AM
  #27
dtsoccer6's Avatar
dtsoccer6
When you order from M7, they offer two kinds of brackets, one to clear most, not all, but most aftermarket intakes. The other is to clear their intake systems as they have a variety. Thank you, I do like the look of it better without the heat shield, it has that cleaner look to it. Again, thanks!
Old Aug 22, 2008 | 05:20 PM
  #28
old81's Avatar
old81
M6
dts, clean install and good pictures. You had me confused for a little while, but then you clarified the mod to the Alta CAI.
Nicely done.
Old Aug 22, 2008 | 10:24 PM
  #29
krim's Avatar
krim
A Breeze to install with all the proper tools, a simple product that made a very large difference torque steer issue and very nice improved handling. Although torque steer is yet to be fully resolved, the M7 Strut Bar was a positive step into a cost effective way of eliminating it. My cornering felt tighter and smoother, and let's face it, the handling on the MINI is by no means bad, but when something can improve on an already great thing, you got a great product. Thumbs Ups to M7. I included some images, more to come.
You probably should check that bolt next to the cross bar in the third photo. Looks like it's going to rub against the bar at some point in rev.
Old Aug 26, 2008 | 10:12 AM
  #30
dtsoccer6's Avatar
dtsoccer6
krim, you were right, i ziptied and and moved the clamp down and now it actually looks cleaner and sturdier than before. the rattle it made was scary at first, i thought my strut tower was falling apart lol. pics when i get home.
old81
thanks for the kind words.
Old Aug 28, 2008 | 03:06 PM
  #31
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Hey guys and gals I don't have the photos handy, but I have put on several of these strut braces with ALTA intakes.
The current ALTA air box DOES interfere and while I didn't think to BEND it like the gent above (although that looks fine) I used a dremel and made a relief in the ALTA air box, then placed the rubber trim back over it. Looks REALLY nice.
I will see about making a template for folks to mark their boxes and include it with the strut braces when they leave here. The aluminum cuts pretty quickly.
NOTE: a newer version of the air box will be out in November that will have that cut already in it.
Finally, on the MAF connector. Rotate the maf such that the plug is away from the bar. Just loosen the clamps and then twist it out of the way.
Let me know if I can help in anyway further!
Old Aug 29, 2008 | 12:16 PM
  #32
dtsoccer6's Avatar
dtsoccer6
hey adam, if I send my old one back to you, could I possibly get a replacement? that would be awesome...
Old Aug 29, 2008 | 12:30 PM
  #33
ADAMSALTAMINI
Lets chat once I have the air boxes done with that relief in it. That kool with you?
Old Aug 29, 2008 | 12:33 PM
  #34
dtsoccer6's Avatar
dtsoccer6
yeah for sure! Alta rocks...check the sig haha
ericbryant24
55
Sep 30, 2024 02:10 PM
ej
Nov 17, 2015 09:21 PM
MINI-Madness
Sep 11, 2015 11:31 AM
cdemarco4
Sep 10, 2015 10:14 AM
Suspension Products
Sep 3, 2015 09:41 AM
