Suspension Longer wheel bolts/lugs for 15mm spacers?
SuspensionSprings, struts, coilovers, sway-bars, camber plates, and all other modifications to suspension components for Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs.
H&R sells longer bolts. You have to measure the factory thread length and the call them with the bolt demensions and they will have all the lengths that they make spacers for. 5mm, 15mm, 25mm
You will need 14mm x 1.25 pitch x 43mm long (stock is 28mm) with a 17mm hex head. +1 on radusa. However they are a gray color. radusa does have lug bolt caps.
The R56 uses 14x 1.25 but H&R does not seem to sell a 5mm spacer for the R56. Am I missing something or do they. Secondly who does sell a 5mm Spacer and does it work with the stock wheel hardware.
I'm using 5mm H&R spacers on my R56. And you will want 5mm longer wheel bolts.
My 15mm H&R spacers have large enough holes for the 14mm lug bolts. I am using them on a late 2006 R53 GP which has the aluminum trailing arm and 14mm lug bolts like the R56.
