Suspension Just installed cf strut bar
Old Apr 14, 2008 | 06:03 PM
Kwin's Avatar
Kwin
Hey I just intalled a carbon fiber strut bar i purchased from a fellow Namer. I had a feeling the ecu cover wouldnt fit but i was hoping by some grace it would fit . So i installed it and i was able to squeez it in. So i took it out for a spin...it felt nice..popped the hood looked for anything wrong looked fine. Closed hood and the right side doesnt fit fully . So im planning on going out later tonight and taking off the ecu cover and shaving it down a bit. Im guessing the ecu doesnt like heat so ill do my best to leave as much plastic on there as possible. Anything else i should look out for?
Old Apr 14, 2008 | 07:35 PM
Kwin's Avatar
Kwin
no answers
Old Apr 14, 2008 | 07:36 PM
PGT's Avatar
PGT
any pictures?
Old Apr 14, 2008 | 08:10 PM
Kwin's Avatar
Kwin
yea i do just have to upload them
Old Apr 14, 2008 | 09:07 PM
that7guy's Avatar
that7guy
Pictures would help
Old Apr 14, 2008 | 10:08 PM
Kwin's Avatar
Kwin
hahah im soo lazy ill have em tommorow, i have no work tommorow
Old Apr 14, 2008 | 11:45 PM
06PWMCS's Avatar
06PWMCS
Pics!
Old Apr 15, 2008 | 03:46 AM
davavd's Avatar
davavd
At first it fit and then it didn't??
Old Apr 15, 2008 | 10:05 AM
freeskier's Avatar
freeskier
the material attached to the under side of the hood needs to pack down or be shaved a little sometimes.
Old Apr 15, 2008 | 02:14 PM
Kwin's Avatar
Kwin
no haha i closed the bonnet and didnt really look at it. so i took it out for a spin and looked at it again and i then saw that the bonnet locks but the right side stays up. I can still fit a finger under the right side to get the bonnet lock but it wont open cause its latched
Kwin's Avatar
Kwin
exactly will be shaving the ecu cover, just wondering if theres anything to watch out for
Old Apr 16, 2008 | 10:21 AM
amg6975's Avatar
amg6975
Why are you shaving the ECU cover? That's not going to make the strut bar any lower... you need to get rid of some of the matting material on the underside of the hood.
Old Apr 16, 2008 | 08:05 PM
MRmidge's Avatar
MRmidge
Moss sells a low profile ECU cover if your experiment doesn't work so well. Here is a link
http://www.mossmini.com/Shop/ViewPro...eIndexID=59562
Old Apr 16, 2008 | 08:52 PM
Longboard Mini's Avatar
Longboard Mini
If the ECU cover fit under the bar then IT"S NOT THE PROBLEM.
The hood liner is hitting the bar. Try the old soak and slam. Get a spray bottle and soak the area of mat that hits the bar. Once it is saturated slam the hood shut a couple time. You may need to repeat this a couple times but it does work.
If you still have the problem then try trimming the liner.
My $.o2
LB
Old Apr 17, 2008 | 05:36 AM
Kwin's Avatar
Kwin
Yea you guys are right i shaved the ecu and even part of my air box, the hood closes a bit more but i will try the spray bottle method and will shave some of the hood if that does not work, thanks for the suggestions
pics when im not feeling lazy
adrchn
Aug 13, 2019 02:11 AM
Mikli
R55 :: Clubman Talk (2008+)
Jun 26, 2019 05:58 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
nomar116
Aug 10, 2015 11:24 PM
