Suspension Control Arms
Old Mar 23, 2008 | 05:56 PM
ANT818's Avatar
ANT818
Control Arms
Anyone put after market upper & lower control arms on their R56 with JCW suspension??
Old Mar 23, 2008 | 06:00 PM
Guest's Avatar
Guest
Camber Arms? I'm not aware of any aftermarket offerings of control arms for the R56 (Or the R53 for that matter). The control arms are the big steel supports that hold the wheels on. The thin, almost sheet metal looking arms that strut out on the top and bottom are camber arms.
Old Mar 23, 2008 | 06:09 PM
ANT818's Avatar
ANT818
That logic sound correct. However, most of the sites selling after market suspension parts for the mini refer to them as control arms. Go figure.
Old Mar 24, 2008 | 05:10 AM
Arnbut's Avatar
Arnbut
Dirty car; clean camber links:
Old Mar 24, 2008 | 11:26 AM
ugliboi_87's Avatar
ugliboi_87
sorry for the dumb question,
can anyone explain to me, what are these control arm do to your car? are those require when u're lowered your car?
Old Mar 24, 2008 | 11:47 AM
Arnbut's Avatar
Arnbut
You might like to install the lower camber link if you intend to use a variety of wheels/tires and have track days.
I don't think that the JCW bits will lower the car more than the stock adjuster can handle.
The links adjust the vertical alignment of the rear wheels latterally. The upper controls toe.
Old Mar 24, 2008 | 12:19 PM
lttletimmy's Avatar
lttletimmy
adjustments on the bottom also affect toe because the arm doesn't line up to the wheel hub at the center. Increasing negative camber also increases toe in slightly, and vice versa.
Old Mar 25, 2008 | 08:07 AM
rjtrout2000's Avatar
rjtrout2000
what springs do you have?
Old Mar 25, 2008 | 09:26 AM
Arnbut's Avatar
Arnbut
H&R + Hotchkiss 25.5mm RSB.
Old Mar 25, 2008 | 09:36 AM
rjtrout2000
Sweet. Sounds nice!
What I would say for the original topic is this:
If you drop one inch or less, then OEM hardware should work. This covers JCW, H-sport, and TSW.
More than an inch Tein, H&R, M7, etc... rear control arms would be great in order to dial in the ride's proper alignment.
Everyone can use these, but many people don't need them. I thought of getting a set of Alta arms to sharpen my response, but it sounds like an expensive mod given that these wear out faster than OEM by a long shot.
Just my .02
bahman
Nov 15, 2019 05:45 AM
Mrbrown
Suspension
11
Dec 31, 2015 09:31 AM
Suspension Products
Sep 10, 2015 11:46 AM
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
