Suspension lower with Eibach - alignment
Old Mar 10, 2008 | 04:55 AM
donuttang's Avatar
donuttang
How to read the result?
I just did the alignment, is it a good setup...
sorry, i just modified the before with English, i guess you can guess the setting....if not, i will change all into Eng....
thanks...
Attached Thumbnails lower with Eibach - alignment-before.jpg   lower with Eibach - alignment-after.jpg
Old Mar 10, 2008 | 02:30 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
They should have given you more - camber on the front right. There is a hold down screw on top, remove it. Then loosen the 3 top strut screws and move the top of the strut towards the engine. The holes are slotted.Easier if you raise car to get weight off tire.
On the right rear they gave you more - camber, you want less in rear.
Maybe the left wouldn't come in anymore, so they evened it up.
Hope that helps. You could think about buying lower rear control arms and taking more of the negitive camber out of the rear.
http://www.altaminiperformance.com/p...r-Control-Arms
Old Mar 10, 2008 | 03:18 PM
ThumperMCS's Avatar
ThumperMCS
you can adjust front camber on a stock mcs?
Old Mar 10, 2008 | 04:05 PM
th3118's Avatar
th3118
Yes, on the R56 you can get almost .4 negative camber if you follow the above procedure.
Old Mar 10, 2008 | 04:12 PM
ThumperMCS's Avatar
ThumperMCS
Thats cool to know!
smdmini
Oct 7, 2019 06:05 AM
LAcooper
Sep 22, 2015 10:03 PM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
hydouken
Sep 15, 2015 05:49 AM
Sep 2, 2015 11:15 AM
