Suspension 18 Inch Rims, Lowered...Crap!
So, I purchased an 02 Mini Cooper a couple months ago, Love it! Except it has 18 inch rims and is lowered. The lowering springs have gone out in the rear and I think I'm just going to get new springs. The tires are 225/40 18 which I think is too big anyway. Should I just get the springs fixed and then get smaller tires later? The rims are actually quite nice so I'm reluctant to get rid of them.
I run 215-35-18 and its not a problem in terms of rubbing. Alot of other people are running this same setup and its not a problem either. In terms of ride quality, its not horrible...but maybe I am just used to it.
Depending on the size of your rims, you might want to think about going to a 205/40/18 or a 215/40/18. I myself run a 215/35/18 and it's true that you need to watch out for bad road ALL the time. It won't take much to wreck a rim with that size tire. I plan on going to a 215/40/18 next time around. My 18's are a 18X7.5.
Stock Rolling dia. on first gen Minis was 24.26mm (with 17" rims)
Going +1s with these on 18s means that you'd want 225/35s (24.20) or 215/35 (23.93) - speedo reads high
215/40 (24.77) - speedo reads low
Your current 225/40s have a rolling dia or 25.09, so your speedo is reading much slower than you are actually going...
When you say that the lowered springs have gone out, I'm assuming you mean that they broke... so I'd replace them with stock units if you don't mind the higher ride height.
Thanks everyone!
Mine are 18X7.5 also.
I wasn't sure if the tires would fit right if I put the stock springs on. I think I would rather have the stock setup because I live in pothole heaven, which is why I think the springs are broken in the first place! If the car is going to look ridiculous with the huge rims at stock height I might just take the tires down a size. I don't even know!
Also- I thought the speedometer was off! It's a wonder I haven't been pulled over because I've speeding according to the car already- ha.
malibujoey
Nov 9, 2015 08:22 PM
