Suspension Why are new endlinks important for upgraded sway bars?
Old Feb 27, 2008 | 02:00 PM
MiniJayhawk's Avatar
MiniJayhawk
Someone explain to me why new endlinks are necessary for an upgraded rear sway bar like Alta 22mm or H&R sways. I plan to get lowering springs and a new stiffer rear sway. Thanks!
Old Feb 27, 2008 | 02:06 PM
thefuturequeenofnebraska's Avatar
They arent.
We'd recommend a 19mm H-Sport for you, and you can use the stock endlinks with it
Hope that helps!
Old Feb 27, 2008 | 02:28 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Necessary is a relative term. Will they help under hard cornering yes, will the OEM ones break, unlikely. BUT you will loose some of the benefits from the new swaybar purchase through.
Also on the adjustable links, you can do other things to help setup the suspension response, but I am leaving that out for now.
My thought would be if you want to do the 22mm bar and need that much uphm from it, then you SHOULD get the ALTA (or similar) endlink upgrades.
The 19mm is likely ok with the OEM links.
Let me know if I can help further!
Old Feb 27, 2008 | 03:33 PM
MiniJayhawk
Thanks guys. Now go to work explaining the difference between your bars and the JCW rear bar for the R56.
And Adam, how do your endlinks provide that extra umpf? I will track the car. (I instruct DEs)
Old Feb 27, 2008 | 05:25 PM
PGT's Avatar
PGT
short of adjusting length on a lowered, there's little reason to change endlinks in my experience. YMMV
Old Feb 27, 2008 | 06:28 PM
gnatster's Avatar
gnatster
Since the OEM ones are not adjustable there will be some bar preload. But until you go with coilovers and start corner balancing it really doesn't matter.
Old Mar 5, 2008 | 09:19 AM
jasonsmf's Avatar
jasonsmf
Ignoring the adjustability side of things, OEM endlinks usually hold up just fine for an upgraded sway bay, yes. BUT they are lacking in the stiffness department. Eventhough they are not failing, they are reducing the effectiveness of the sway bar when they flex. Upgraded endlinks are much stiffer than OEM.
Jason
Old Mar 5, 2008 | 10:07 AM
MiniJayhawk
Flex where? They are a point to point connector with rotating connection points. Even the aftermarket adjustable ones. They are supposed to flex at those points. All they do is maintain a specific distance between two connection points.
Old Mar 5, 2008 | 11:59 AM
jasonsmf's Avatar
jasonsmf
With the added force from a uprated swaybar, the endlink body itself can act like a spring, the distance between the two points can change as the body flexes under that load. We are not talking a lot of deflection here, but any compliance in the linkage reduces the stiffness of the swaybar.
Jason
Old Mar 11, 2008 | 01:39 PM
ugliboi_87's Avatar
ugliboi_87
i'm sorry, i'm new about car, can anybody explain to me what's is OEM endlinks? .....
thank youuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu
Old Mar 11, 2008 | 01:44 PM
glnr13's Avatar
glnr13
OEM=stock
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
BRracing
Dec 22, 2015 09:25 AM
minimofo
Sep 9, 2015 10:29 AM
