Suspension Strut Tower or Underside Brace? Another one..
Old Jan 24, 2008 | 11:54 PM
  #26
HighLife4136's Avatar
HighLife4136
Old Jan 25, 2008 | 10:36 AM
  #27
OldRick's Avatar
OldRick
HighLife - got a picture of these "Diagonal Rods"?
What do they bolt to on the frame?
Old Jan 25, 2008 | 10:58 AM
  #28
rkw's Avatar
rkw
Look at this thread: https://www.northamericanmotoring.co...d.php?t=100375
Old Jan 25, 2008 | 11:00 AM
  #29
maxmini's Avatar
maxmini
Rick the rod he is talking about is the black diagonal tube the the right of the picture alongside the inner fenderwell liner. They are the additional bracing used with the convertable.
Randy
M7 Tuning
Old Jan 25, 2008 | 11:14 AM
  #30
mmatarella's Avatar
mmatarella
Have and will be installing the TSW underbrace on my cabrio. I would do the M7 for the anti mushroom and upper brace but am not crazy about the solutions that have to be done to not distort the hood. (When doing the upper M7 brace)
Is there another upper brace that has big plates to prevent mushrooming that doesn't require crushing /removing some of the underhood pad? Or another bar that will co habitate with just the M7 plates? Oh and I have the Alta CAI if the changes clearances at all. Seem to remember a issue with some braces and either the stock air box or the Alta...
If not I lean towards just the M7 plates up top. I'm putting a higher value on not mushrooming than on the apparently small gain from a upper strut. I run 17 inch non run flats in a 45 profile so I'm not sure how great my risk of 'shrooming really is either.
Old Jan 25, 2008 | 11:30 AM
  #31
maxmini's Avatar
maxmini
To answer a few of your questions personally I have not seen another bar with the end plates that would assist in the antimushroom situation as well as ours .As for adding another bar on top that would be a no as the plates are too thick to allow another bar to be used.I can say that you will notice a really big difference with the TSW brace as the cabriole begs for additional support whether it is ours or another companies.
Randy
M7 Tuning
Old Jan 25, 2008 | 12:05 PM
  #32
mmatarella's Avatar
mmatarella
Thanks Randy! I'll be getting your plates at the least...
Old Jan 25, 2008 | 08:47 PM
  #33
blackie's Avatar
blackie
Frankly, I used the soaking of the under-bonnet blanket method and it worked just fine. I think it requires a true and thorough effort, meaning a large spray bottle (filled and emptied twice) and meticulous soaking, so the blanket really absorbs a very large quantity of water. I wrapped the brace in plastic wrap first and slammed the hood when the blanket was thoroughly soaked then left it closed for over a full day. The indentation in the blanket that remained was sufficient to accept the extra height that was added by the STB and the bump in the bonnet really became a non-factor.
Old Jan 25, 2008 | 09:09 PM
  #34
maxmini's Avatar
maxmini
Nice How To Blackie . I wish I had known about it back when I had my BMP brace . I never knew about the " bulge " issue until it was mentioned with regards to our brace . When I switched out the BMP to ours I realized that I had already been " bulging " for over 2 years and never realized it. I think the bulge only really became a issue when it was our bar making it Thanks again for the nice write up.
Randy
M7 Tuning
Old Feb 1, 2008 | 03:55 PM
  #35
SPDinNY's Avatar
SPDinNY
is the M7 USS worth $125 more then the mini madness one? I cant find the M7 one for under 348.99
Old Feb 1, 2008 | 05:50 PM
  #36
ScottinBend's Avatar
ScottinBend
now that's a question...........!
IMHO.................NO
Old Feb 1, 2008 | 09:20 PM
  #37
AllBlack05S's Avatar
AllBlack05S
Originally Posted by DrPhilGandini
Another vote for: top brace does not produce noticeable effect.
I have to disagree with that. Installed the M7 STB on an otherwise stock S-no USS in place to dampen the effect. It does make a difference particularly during sudden direction changes and high speed sweeping turns that normally cause the front end of the car to flex.
Looking at the designs of the Madness lower strut brace, the OMP lower strut bar and M7 USS. I would say that the M7 unit (which I will eventually buy) should do more to stiffen the whole car. The other units will do their jobs fantastically. The M7 USS just takes on more work.
As to a comment about bolts vs. welds I read above, aircraft are not welded together they are bolted and riveted together.
To answer the original question: A full car USS will do more to stiffen the car than either an upper or lower strut only brace. A lower strut only brace will stiffen the chassis, so will an upper. Neither will vastly improve on the other but together are better than just one.
Don't forget to do the back of the car, it flexes too. Randy has a massive rear brace that might be overkill for some uses. Other sites sell the rear upper brace that is only a traditional single bar. At under $100 it will also add a bit to stiffness. Either one will add to an overall improvement. Your wallet will decide how stiff you want your car in the end.
Do uppers first see if that is enough (you'll want to see how much more you can get out of it, so it won't be). Then buy parts to stiffen the bottom end of things. The reason I suggest that order is simple. The bottom of the struts are already tied together better than the tops. Go for the weakest points first.
Old Feb 2, 2008 | 05:22 AM
  #38
SPDinNY's Avatar
SPDinNY
My car is a cabrio. So far I have ordered a Hotchkis 25.5 competition rear sway and Hotchkis upper strut bar. I dont know if they make a rear upper bar for the Cabrios do they? If so then maybe I would be better buying the minimadness brace and the rear upper strut bar.
Old Feb 2, 2008 | 02:10 PM
  #39
rlandrews3rd's Avatar
rlandrews3rd
The webpage specifies that the bar fits the "S", and I have a 7/02 R50, "justacooper". Will the Mini Madness lower stress bar fit my Mini?
Old Feb 2, 2008 | 02:18 PM
  #40
ScottinBend
No difference in application......should fit no problem
Old Feb 2, 2008 | 02:23 PM
  #41
ScottinBend
Why would you order a race sway bar for the street? This even stiffer than the 22mm Alta....
  #42
YakiMini's Avatar
YakiMini
+1 It will fit!
Old Feb 2, 2008 | 02:33 PM
  #43
rlandrews3rd
Glad to hear that it'll work on my car. I think I'll take AllBlack05s's advice and do the top first, then the bottom later on. The anti-shroom effect of the M7 upper brace is a good thing! I'll add the Mini-Madness under body to my list. Thanks!
Old Feb 3, 2008 | 09:18 AM
  #44
SPDinNY's Avatar
SPDinNY
a fellow mini owner has it on his Cabrio and its fine set to the softest setting. Since its hollow its lighter but I think has the same effect of a 22mm.
Old Feb 3, 2008 | 10:21 AM
  #45
ScottinBend
It is actually a bit stiffer than the Alta 22mm.
Hope you like it.
Old Feb 4, 2008 | 10:08 AM
  #46
OldRick's Avatar
OldRick
The USS brace ties more points together than the other alternatives - a plus.
However, it could certainly work better if the it was welded at the corners like the Mini-Madness, or, even better, triangulated like the TSW. Unfortunately, the latter two don't tie as a many points of the chassis together, so presumably they could work better too.
One might hazard a guess that they would each work roughly as well, due to the shortcomings of each design. The OMP single-bar is probably not quite as effective as the others.
That leaves price and/or bling as a factor, with the OMP getting my bang-for-the-buck award. The M7 is certainly up there re. both bling and high price.
Whatever else you do, the Cabrio "diagonal brace" is a star in the bang-for-the-buck department, and should be your first choice if money matters to you. It is also the ONLY front brace that resists vertical impact to the front subframe in any way, and thus should be a nice improvement when used along with any of the other braces.
I note that maxmini uses the OEM brace, even though he doesn't sell it, which I view as a pretty good endorsement.
Old Feb 4, 2008 | 10:49 AM
  #47
maxmini's Avatar
maxmini
I've had the diagonal brace on almost since the first convertibles came out. I was first interested in the idea when one of the NAM "experts " said that you couldn't get them without owning a convertible . Seemed like BS to me so I thought it would be fun to prove him wrong. Was able to get them with no problem and have had them on ever since . I do think that anything that helps tighten up the chassis is a good thing .The way the front arms that cradle the engine stick out like that they can use all the help they can get whether it be on top or below.
As for welding verses bolts , as one of the other members posted earlier if you can bolt a airplane together it can't be all bad. The way the pieces are notched and then bolted together make for all the strength necessary to do the job. I have the first prototype unit still on my car and it is as solid as the day we put it on.
Randy
M7 Tuning
Randy
M7 Tuning
Old Feb 4, 2008 | 10:54 AM
  #48
gnatster's Avatar
gnatster
Aren't aircraft designed to flex some?
Old Feb 4, 2008 | 11:00 AM
  #49
maxmini's Avatar
maxmini
Not everywhere .
Randy
m7 Tuning
Old Feb 4, 2008 | 11:23 AM
  #50
agranger's Avatar
agranger
PS: It's easier to see the convertible braces when they are painted red! :D
Do they do anything that I can notice for performance/handling? Not at all.
Do they look cool? I think so.
Are they different? On a hard-top, yes... especially when painted red.
Do I like the idea of reducing flex? Sure.
Do I have any data to show that they do anything good for the car? No... but this is NAM... it's never stopped anyone before!
