Suspension Q About getting a new suspension.
Old Oct 27, 2007 | 01:49 PM
gvoelker's Avatar
gvoelker
I'm already equipped with a stiffer rear swaybar, and was wondering what other supporting modifications I need for the MINI to handle the lowering. Will I need camber plates and new rear control arms?
Just curious before I go destroying my wallet! :impatient
Thanks guys,
G
Old Oct 28, 2007 | 05:51 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
That depends on how much it will be dropped. If the car is lowered too much it will add too much negative camber in the rear. The front will have no camber gain. To fix the rear and get it set where you want, you will need at least the lower control arms. But I recommend getting all four replaced, that way you can have toe and camber set independantly. If you replace only the lower arms, then your alignment cannot be set exactly.
Old Oct 28, 2007 | 04:15 PM
RedSkunk's Avatar
RedSkunk
If you're only lowering an inch or so, rear camber won't be terribly out of wack. Also depends on what you're using the car for. If you're just looking for an enjoyable driver, then chances are the extra camber in the rear won't be a deal breaker for you. Many camber plates and control arms introduce more NVH (noise, vibration, harshness) resulting in a car harder to live with day-to-day.
Prioritize and go from there.
Camber plates are a great mod though FWIW.
Old Oct 29, 2007 | 07:01 PM
gvoelker's Avatar
gvoelker
Thanks for the replies guys! I think i'll just go with the suspension itself, because it's pretty much a daily driver only.
massmini03
Sep 18, 2015 05:40 PM
The Rossness
Sep 17, 2015 03:06 PM
RDSJCW
Sep 16, 2015 03:54 PM
atlantaorange
Sep 16, 2015 12:43 PM
HaveATank
Sep 16, 2015 08:32 AM
