Suspension Lowering springs or adjustable coilovers?
Old Oct 23, 2007 | 10:01 PM
mogollon8266's Avatar
mogollon8266
Thinking on lowering my R56. what's the best choice lowering springs or adjustable coilovers?? pros and cons, which one rides better??
Old Oct 23, 2007 | 10:24 PM
scott48's Avatar
scott48
Depends on your needs. If you just want it lowered for looks, but also for handling, and a stiffer spring for handling, just get the springs. If you want increased handling get the adjustable coilovers. You'll also be able to adjust your ride height for looks, or clearance issues for where you drive, or if you want to track your car, you'll be able to fine to the handling. Coilovers will ride stiffer since your changing shocks and springs, but the dampening will be correct, where as just getting springs, the dampening might not be 100% correct which will hurt the ride.
Old Oct 24, 2007 | 10:44 AM
mogollon8266
but can you adjust how stiff you want coilovers to be soft or stiff
Old Oct 24, 2007 | 12:33 PM
scott48's Avatar
scott48
Yeah, but depending on what kind/brand you get, you'll be able to adjust more or less things.
Old Oct 24, 2007 | 01:52 PM
ninja_van1sh's Avatar
ninja_van1sh
i have a brand new set of r56 HR coilovers if u want :D $850 never used!
Old Oct 24, 2007 | 06:46 PM
mogollon8266
thanks for the offer but I'm thinking on going with the m7 coilovers thanks
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
BRracing
Dec 22, 2015 09:25 AM
yukinoinu
15
Aug 24, 2015 09:20 AM
Emnotek
Aug 13, 2015 05:47 PM
OutMotoring
Aug 6, 2015 09:32 AM
