Suspension spring rate conversion ?
Old Oct 1, 2007 | 07:40 AM
03Indigo's Avatar
03Indigo
User Title's are Silly
how do you convert spring rates?
I was given the rates of some springs, both progressive and linear, but they are in N/mm...and I am used to seeing them in KG or #s.
Anyone have a conversion matrix or can direct me to something that can help me translate rates into something I can more understand?
thanks
Old Oct 1, 2007 | 08:09 AM
Partsman's Avatar
Partsman
Legion_of_Doom
To convert kg./mm. to.......lb./in. ......N./mm.
multiply by ....................55.998........9.807
To convert lb./in. to ......Kg./mm. ......N./mm.
multiply by ................0.017858......0.175133
To convert N./mm. to .......Kg./mm. ......lb./in.
multiply by ...................0.101968......5.7099
From this website...
http://leespring.com/tolerance1.asp
Hope that helps.
Old Oct 1, 2007 | 08:12 AM
03Indigo's Avatar
03Indigo
PERFECT....thanks for the prompt reply....I will update my suspension thread with the information I got from Vogtland.
Old Oct 1, 2007 | 08:20 AM
jakay11's Avatar
jakay11
All you have to do is break out your trusty web-based converter and have at it...
so
100N = 12.2 KG(force) = 22.5 lb(force)
and 1" = 25.4mm
*USUALLY* when some one says that they have a 100lb spring, they really mean 100lb/in (or what ever that converts to in kg/mm)
HTH.
Old Oct 1, 2007 | 08:35 AM
Partsman's Avatar
Partsman
Legion_of_Doom
You're welcome, glad I could help. Good luck.
nashvillemini
Sep 30, 2015 10:26 PM
rt808
Sep 29, 2015 03:15 PM
gnhovis
Sep 28, 2015 10:56 AM
massmini03
Sep 18, 2015 05:40 PM
tylewis
Sep 6, 2015 07:36 PM
