Suspension front sway bar vs strut bar.
Old Sep 10, 2007 | 09:02 PM
thlaxx's Avatar
thlaxx
what would be the difference besides obviouse placment and shape of each. pros and cons of each? is one better for something than the other?
Old Sep 10, 2007 | 10:28 PM
scott48's Avatar
scott48
Sway bar reduces body roll by tying the front suspension(on the struts) together...a strut brace increases the chassis' torsional rigidity(less flexing). You'll notice a much bigger handling difference by getting a sway bar. So get sway bar then strut brace.
Old Sep 10, 2007 | 11:11 PM
ScottRiqui's Avatar
ScottRiqui
I'd go with the sway bar first as well. In particular, you'll probably get more-noticeable results by swapping out the rear sway bar. Most people just leave the front bar stock.
Old Sep 11, 2007 | 12:46 AM
steve11's Avatar
steve11
Going for a heavier rear sway bar will help cure understeer. Dont bother changing the front one.
The strut brace doesn't do a lot, but certainly wouldn't hurt.
Old Sep 11, 2007 | 12:40 PM
thlaxx's Avatar
thlaxx
thanks! I was thinking of getting the H & R rear sway bar. Its for the r53 but, everyone has said it same setup and it will fit.
Toolman
Jan 20, 2016 06:50 AM
minipopkart
Aug 13, 2015 05:22 AM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
