Suspension JIC/Cross suspension for MCS 07 installed
Old Aug 23, 2007 | 12:04 AM
jk997tt's Avatar
jk997tt
JIC/Cross company just installed R56 MCS mono turbe full coil over suspension. they are 15 way dampning adjustable front inverted mono tube and rear mono tube damper. ride feel 10% harder than origenal factory sports suspension. very nice ride. hundling is very nice. I can't wait go to race track.
Attached Thumbnails JIC/Cross suspension for MCS 07 installed-dsc00364.jpg   JIC/Cross suspension for MCS 07 installed-dsc00369.jpg   JIC/Cross suspension for MCS 07 installed-dsc00376.jpg
Old Aug 23, 2007 | 12:05 AM
jk997tt's Avatar
jk997tt
more photos
Attached Thumbnails JIC/Cross suspension for MCS 07 installed-dsc00365.jpg   JIC/Cross suspension for MCS 07 installed-dsc00372.jpg   JIC/Cross suspension for MCS 07 installed-dsc00370.jpg
Old Aug 23, 2007 | 08:12 AM
a96bimmerm3's Avatar
a96bimmerm3
Adjustment looks like a royal PITA. Cutting of the strut tops looks semi necessary to adjust the plates easy. Please say thats not the case (and more pics please!)
Have fun!
Josh
Old Aug 23, 2007 | 08:20 AM
PGT's Avatar
PGT
Have fun!
Josh
same for any camber plate and most coilovers.
Old Aug 23, 2007 | 12:44 PM
ninja_van1sh's Avatar
ninja_van1sh
how much?
Old Aug 23, 2007 | 12:55 PM
ScottRiqui's Avatar
ScottRiqui
Have fun!
Josh
I have these on my R52. The adjustment isn't as bad as it looks, because if you move the silver lockdown bolts more toward the center, you can reach them through the hole in the shock tower using a ball-end hex driver. If you look at the top of the camber plate, you can see the alternate holes that you can use for the bolts. It still might be a little tighter fit than with the first-gen cars, though.
Old Aug 23, 2007 | 02:21 PM
a96bimmerm3
Perfect explanation!!!! Thank you so much!!!!
Old Aug 24, 2007 | 06:12 AM
ficcion's Avatar
ficcion
What is the max negative camber up front you can achieve without the spring hitting the body (if that is even a problem)?
Old Aug 24, 2007 | 11:01 PM
jk997tt's Avatar
jk997tt
Depend ride height and wheel offset should be able to make around -3.5degree. if need more need modify little bit panel then more. I will update more detail info later.
Old Sep 10, 2007 | 11:10 AM
snid's Avatar
snid
Not true for the Helix plates for the pre-2007 cars. You can adjust the plates without having to cut up the strut towers.
Old Sep 10, 2007 | 04:44 PM
dmh's Avatar
dmh
...which is nice but the penalty you pay is weight -- they are by no means light.
Old Sep 10, 2007 | 05:11 PM
PGT's Avatar
PGT
and stack height IIRC
Old Sep 11, 2007 | 08:33 AM
meb's Avatar
meb
Wheel offset and ride height should have anything to do with camber angles
Nice kit by the way.
Old Sep 11, 2007 | 08:42 AM
Revolution Mini Works's Avatar
I have ridden in the car above, it is by far the best riding/handling R56 I have ever ridden in. After the test ride I went back to the shop and bought a set for my GP!
Revolution Mini Works is now carrying the Cross/JIC coilovers.
The R56s should be in shortly as they are finished and are being shipped from JAPAN!
Old Sep 13, 2007 | 07:43 AM
Helix13mini's Avatar
Helix13mini
The Helix camber plate weighs 28 ounces more than stock, adding a whopping 3.5 pounds to your car. It also adds the best protection available against mushrooming, plus it's easy for any competent mechanic to install them correctly on the first try.
Old Feb 17, 2009 | 06:08 PM
Oxybluecoop's Avatar
Oxybluecoop
Nice setup looks good!
maestro39
Oct 27, 2015 02:38 PM
squawSkiBum
Oct 2, 2015 09:21 AM
nomar116
Aug 10, 2015 11:24 PM
