Suspension Koni FSD with lowering springs
Old Jun 18, 2007 | 10:11 AM
  #26
cajun's Avatar
cajun
Well I Was using FSD's with TSW springs. I just had one of the rear shocks fail on me. Not cool. What I know now. If I had to get another shock, I would have gone with the Koni Yellows verse the FSD's... The FSD's would have been fine if I would have stayed with the stock springs.
Old Jun 18, 2007 | 10:17 AM
  #27
kenchan's Avatar
kenchan
cajun- sorry to hear. thanks for the info for us other users that
are considering dampers for our lowering springs. your experience will not
be put to waste.
Old Aug 27, 2007 | 03:47 PM
  #28
lunlun's Avatar
lunlun
does either koni FSD or koni yellows come with some sort of warranty ?
Old Aug 27, 2007 | 04:01 PM
  #29
lunlun's Avatar
lunlun
From outmotoring.com
"KONI shocks have a lifetime warranty. Try getting that from the tuner garbage (insert initials here). Available for all MINI's with build date after 3/1/02 (see drop down menu for applications) Sold as a complete set of 4 only. Please allow 2-4 business days before we ship."
So wouldn't it be okay to install the FSD into a lowered mini, if it get busted ----> ask for new ones since its covered under warranty.
Old Aug 27, 2007 | 04:13 PM
  #30
Mini Works's Avatar
Mini Works
You guys are correct,
Konis do come with a lifetime warranty, they are also really good at helping customers out.
I suggest you send your FSD to Koni, they will probably send you a replacement for free.
Victor
Old Aug 27, 2007 | 04:21 PM
  #31
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Originally Posted by Mike87
I first installed my FSD's paired with H-Sport springs and ran them for about 6 months. With all the talk about not using lowering springs as well as the less than spectacular ride, I changed back to the stock SS springs. Wow, what a difference! The ride is much better than with the H-Sports and it seems handling has not changed. It did raise the car about an inch all around, so I am sure that the weight transer is different, but so far I cannot feel a handling difference. I had the car aligned the same as with the H-Sports.
All in all, I am happy! And that is what counts.
Currently Alex@tirerack.com recommends stock springs with Koni FSD for best results. You can ask him about Koni warranty in case you use it with lowering springs.
Old Aug 27, 2007 | 04:53 PM
  #32
MarioKart's Avatar
MarioKart
Vendor
I have run FSD with HSport and now even lower M7 springs. Everthing has been great for 7000 miles
Old Aug 27, 2007 | 05:26 PM
  #33
Central Coast Coopers's Avatar
32000 AND COUNTING
THE very early set of FSDs, on my car since oct 05, have gone over 32k with first h sport, then H&R springs, so far no issues whatsoever. In addition (sounding like a broken record here) I have installed over 20 sets with lowering springs and not had any issues with those cars either. On occasion, mass produced automotive parts fail ---Your results may vary..........................
Old Aug 27, 2007 | 07:40 PM
  #34
minimarks's Avatar
minimarks
Do FSD's raise the height of the car when on lowering springs? IE: 1" lowered car would be less than 1" after installing FSD'S...Sorry to get off thread a little....
Old Aug 27, 2007 | 07:45 PM
  #35
PGT's Avatar
PGT
still doesn't mean using them against the manufacturer's recommendation is a prudent strategy for warranty replacement (if needed).
Lee Grimes at Koni implored me to use stock springs with FSD's on the MINI....told me if I wanted it lowered to use Yellows instead. YMMV
Old Aug 27, 2007 | 07:59 PM
  #36
Mini Works's Avatar
Mini Works
PGT I will agree with you and Lee Grimes from Koni.
Koni designed the FSTs specifically to work with the factory springs.
That said, I know that a lot of you run the FSds with lowered spring, without any problems, but does not mean that the shocks are working to 100% of their ability.
I know it has been said many times, but the koni yellows are a proven shock, probably the best out there to be used with lowered springs.
Victor
Old Mar 21, 2018 | 02:23 AM
  #37
Sagrit R53's Avatar
Sagrit R53
R53 s 04 suspension upgrade
So i am about to upgrade the suspension and aftet reading a lot in here and not only i came to the following choises
FSD with eibach pro
koni yellows with eibach pro
ST coilivers
KW V1 coilovers
my goal is to have a small amount of lowering around 20mm or 0.75 inches with lots of comfort while maintaining reasonable handling.
i want to use the 17' GP wheels (485)
with 215/40 or 45 tyres
i want to ask you guys who had one of the above setup how is your experience and how many miles you currently have on them. Nowadays the price range for all setups above is around 700 - 950 euro
Old Mar 21, 2018 | 04:44 AM
  #38
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
comfort and stiffer shocks do not go together
I have jcw springs and koni yellows, it's stiff the wife hates it
I had FSD with the jcw springs, no where near as stiff but it would bottom out hard on big hits
Old Mar 21, 2018 | 04:56 AM
  #39
Sagrit R53's Avatar
Sagrit R53
thanks for reply! Appreciated.
How about adjusting the yellows to less stiffness? Aren't they adjustable?
how many miles on those jcw springs?
what wheel size are you using?
and how many fingers from the top of the tyre to bottom of the body? Does your car look level on your current setup?
That information would help me a lot.
ps sorry for bad English
Old Mar 21, 2018 | 05:03 AM
  #40
Whine not Walnuts's Avatar
Whine not Walnuts
Are you talking linear or progressive springs as the later has more ability to offer softer rides on straight type driving?
Are you throwing in the cost for longer front end links and thinking your 04 will have the non-adjustable rear control arm that will require new adjustable type.
Old Mar 21, 2018 | 05:04 AM
  #41
Whine not Walnuts
and glad to see another old thread getting new views.
Old Mar 21, 2018 | 07:46 AM
  #42
Sagrit R53's Avatar
Sagrit R53
I am trying to get smooth, friendly responsive drive with no banging and crashing noise in every single small pot-hole
eibachs will drop the front 1' and the rear 1.2 it is my closest to the stock available spring option.
that 1.2 rear drop, will it make rear camber more negative than 1.5°? At that point i think i can live with a bit of tire wear if any.
My choises preety much are:
Eibach springs at 150€
koni yellows adjustable at 540€
koni FSD at 530 €
ST coilovers around 650-800
KW V1 coilovers at 970€
i think eibach are progressive and a bit stiffer than jcw which i think would help not bottom out in big holes while maintaining a close to stock height in case of fsd and in the other hand i think they can make the ''stiffer'' koni yellows more friendly with their progressive design having a non full stiff setting ofc on the koni yellow.
what do you guys think? What is your experience?
Old Mar 21, 2018 | 03:47 PM
  #43
Whine not Walnuts
Way Motors is a vendor here and they make a TSW 3/4" lowering spring kit. Still thinking you need longer front end links and adjustable rear control arms to address the camber.
Old Mar 22, 2018 | 05:03 AM
  #44
MrBlah's Avatar
MrBlah
I only crank the stiffness up when I autocross them
springs have 20k miles on them
I run 15x8 and 17x7 wheels
I have no idea how many fingers go there
these are the 17x7
these are the 15x8
Old May 1, 2018 | 07:00 AM
  #45
Subw00er's Avatar
Subw00er
So if we want a more sophisticated ride that doesnt really kill the ability to drive over a pothole, all coilovers are out? What is the option.. fsd and stock springs? I have a r52 jcw so my springs are actually just stock S springs I believe.
Old May 1, 2018 | 08:48 AM
  #46
PokerMunkee's Avatar
PokerMunkee
I'm curious what you go with. I think my R52 S looks great with current stock setup. But the ride is harsh. Original shocks at 56k miles. Don't think I want it any lower.
You can get FSDs on TireRack for $550, plus $50 rebate. Tempting...
Old May 1, 2018 | 08:58 AM
  #47
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
I think in your situation, you are better off with Koni Yellow by keeping the JCW springs being a convertible and your concerns. I think FSD's are too hyped up for the best of both worlds mindset. The yellows give you a lot of latitude. Do remember, the rebound valving adjustment is never linear so don't go to anywhere near the two ends.
Old May 1, 2018 | 11:09 AM
  #48
Subw00er's Avatar
Subw00er
But my springs are not JCW, they are stock S.. I'm really leaning towards the fsd. My stock struts are blown out, so its riding pretty harsh. The car is 10 years old, but only 50K miles, hopefully my springs are still good!? I noticed the rear sagging a bit because of the shocks..
I dont track my car or anything, and I am using very sticky tires, so perhaps the FSD with the 23mm rear sway, IE camber plates and tires is enough to make it handle awesome but give a more sophisticated soft ride for my daily driver!
Old May 1, 2018 | 11:15 AM
  #49
PokerMunkee
I'm leaning towards Ireland camber plates (my strut mounts are cracked), FSD shocks, lower brace, and a rear sway bar. I think we have similar goals to make our 10 year old convertibles a true go-kart that won't break our bodies!
patsum
26
May 29, 2021 06:29 PM
Supertractor3
Apr 7, 2017 11:16 AM
ej
Nov 17, 2015 09:21 PM
Sep 3, 2015 02:06 PM
Sep 2, 2015 11:15 AM
