Suspension Not enough driver side -camber ??
Old May 13, 2007 | 01:18 PM
user 7082082's Avatar
user 7082082
Hello everybody ! So , after getting my car an alignment to fix the toe back to 0 in the front I noticed how I have diff cambers up in front. I am runing IE fixed camber plates and H&R and Bilstein combo. The passanger side is perfect which is at -2.1 where it should be at. The driver side does not want to go lower then -1.0 which is kinda odd so any thoughts on why this is happening ? If this isn't fixable I might just take the plates out and run the same -camber on each side and have it a little less then diff numbers on each side.
Thanks in advance .
LordOfTheFlies
Oct 19, 2015 05:02 PM
RACEnSK8
Aug 31, 2015 01:08 PM
Russter500
Aug 26, 2015 12:11 PM
StuRat
Aug 25, 2015 05:27 AM
messyjesse96
Aug 12, 2015 05:51 AM
