Suspension R53 Coilover for R56?
Old May 11, 2007 | 08:43 AM
MX100's Avatar
MX100
I've been reading and couldn't find a definate answer.
So can someone tell me if the R53 coilover set up is transferable to the R56 platform? If there is some adjustment that needs to be done in order for this to happen, how much work is the adjustment going to be?
Thanks in advance!
Old May 11, 2007 | 03:19 PM
Ryephile's Avatar
Ryephile
The front mounting plate has a different bolt pattern, and the rear shocks will need an aluminum spacer from Helix to key into the rear trailing arm. As long as you can adapt the stock R56 mounting plate to the coilovers and have the ability to order from Helix the rear shock dealies, you'll be good to go.
Teh
Aug 22, 2022 04:37 AM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Hippiehobbit267
Dec 3, 2019 04:22 PM
luisfv56
Aug 22, 2015 12:42 PM
Aug 12, 2015 01:24 PM
