Suspension Cabrio front braces on non-cabrio?
Old Apr 11, 2013 | 12:30 PM
  #176
ZippyNH's Avatar
ZippyNH
Originally Posted by WayMotorWorks
Great, for the price we think the cabrio braces are a no brainer cheapo mod.
Yup..
If it is not already done, IMO do it!
simple if you have a late 2004+ GEN1 HARDTOP!!
Old Apr 30, 2013 | 12:18 PM
  #177
RA082324's Avatar
RA082324
just to add to the knowledge here, i have an r53 cooper s hartop produced in 4/03 without the pre-existing holes.
i purchased the cross braces from waymotorworks, and not only did he get them powder coated the color i requested, but they were delivered on time and look amazing.
as far as the install, i just did it myself in the garage with basic tools. from start to finish, it only took me about 2.5 - 3 hours. that includes jacking up the car, removing the wheels, pulling down the fronts of the fender liners, removing the drive side bracket and the passenger side ground wire, using a punch to mark the drill spots, drilling the holes, tapping the holes, bolting down the braces with the supplied torx bolts from way, re-attaching the wires, putting the fender liners back up, putting the wheels back on, torquing and lowering the car.
i was a bit weary at first of having to drill and tap holes into the car, but it really was simple and only took 3 hours tops.
SO, having said that, anybody that is having doubts or is interested in taking this little project on, fear not. it can be done quite easily, even if you dont have the pre-existing holes. and if you DO have the holes, just spend the $40-$70 and get these things. im about to go for a test drive and see if theres a noticeable difference, but even if not, they look great and add a bit of accent under the hood. worth it in my book.
Old May 10, 2013 | 08:22 AM
  #178
vc1492a's Avatar
vc1492a
I installed these yesterday on my 04, and it actually made a very impressive difference.
I don't know whether it is because I have a sunroof or a mushrooming left shock tower (that I need to take care of this summer), but the car always creaked under load in tight corners and going over some bumps would break your back and send shocks through the steering wheel and seat.
Now, those same bumps are still firm to go over, but the crashing effect is entirely gone. I can also feel a noticeable improvement in front-end stiffness and steering feel.
Best $40 I've spent on the car thus far.
Old May 10, 2016 | 09:49 AM
  #179
sterlingarcher's Avatar
sterlingarcher
Hey, old thread, but a follow-up question. Did you use nuts behind the bolts to secure, or just screw the bolts into the metal with loctite?
Old May 10, 2016 | 10:19 AM
  #180
gaffer's Avatar
gaffer
My early '05 Cooper was drilled and tapped from the factory even though it is a hardtop. All I had to do was order the braces & bolts and put them on. It was very easy.
Old May 10, 2016 | 10:20 AM
  #181
sterlingarcher
Cool. Mine's an '03 without the holes. Looks like I can just drill and tap some and that'll be good enough. No nuts required.
Old May 10, 2016 | 11:32 AM
  #182
AKIndiMini's Avatar
AKIndiMini
Mine is a '04 and it was drilled/tapped from the factory. Some of the holes were covered with stickers. No nuts needed.
Old Feb 17, 2020 | 11:44 PM
  #183
Marc08EX's Avatar
Marc08EX
Anybody have any clue why these braces jumped from $20/pc to $150/pc? I get inflation but DAMN.
Old Feb 18, 2020 | 07:52 AM
  #184
deepgrey's Avatar
deepgrey
Scarcity. The cabrio has been out of production for almost 12 years.
Old Feb 19, 2020 | 10:34 AM
  #185
Yep, they jumped in price, due to volume or a change in supplier. we see that time to time. https://www.ecstuning.com/Mini-2006-...Reinforcement/
If we find a lower cost solution we will let you know.
Otherwise try to find them used in a junk yard R52 with no front end damage.
Old Feb 19, 2020 | 08:34 PM
  #186
mountainhorse's Avatar
mountainhorse
daegerter
Jul 31, 2008 11:09 AM
reeechard
DC Metro MINIs (Archive)
Jun 18, 2007 03:14 PM
Archanum
Chicago MINI Motoring Club
Mar 29, 2006 06:22 AM
MSFITOY
Apr 13, 2004 12:38 PM
