My MCS is leaking!
Old Apr 8, 2007 | 08:46 PM
preppy325's Avatar
preppy325
My MCS is leaking!
Hey guys,
I recently changed the oil this weekend in the MCS. Later on when I drove home, I noticed that my Mini was leaking Coolant. Here is a pic of the hose that's dripping some coolant. Does anyone know what this hose is for or any possible reasons why it's dripping? This hose is a little behind the engine i
believe. Any help would be great.
Old Apr 8, 2007 | 08:56 PM
SRTech's Avatar
SRTech
Originally Posted by preppy325
Hey guys,
Looks like the AC condensation drain. It should only be water, though.
Steve
Old Apr 8, 2007 | 09:24 PM
BillTheCat's Avatar
BillTheCat
Steve's right. Looks like the A/C drain. Any time you drive with the A/C on, that hose will drip water. The more humid it is where you live, the more it'll drip. Here in Florida, they tend to act like garden hoses.
Old Apr 9, 2007 | 07:50 AM
preppy325's Avatar
preppy325
It seems like there is coolant though dripping from that. If I remember correctly, when I saw it, there was an orangeish liquid dripping from it. I can double check, but I'm trying to find out why the Mini keeps sucking up all the coolant. There must be a leak somewhere...Any other ideas on why the Mini would have the coolant at max one day, and then hours later at min?
Old Apr 9, 2007 | 07:52 AM
mbcoops's Avatar
mbcoops
The MINI coolant (from the dealer, factory, wherever) is green, not orange.
mb
Old Apr 9, 2007 | 08:03 AM
Yucca Patrol's Avatar
Yucca Patrol
Many of us have had the plastic coolant bottle split at the horizontal seam in the middle of the bottle.
Look behind your bottle and see if there is white powdery stuff on the heat shield beneath it.
That is what explained my loss of coolant a few years ago.
Old Apr 9, 2007 | 09:49 AM
preppy325's Avatar
preppy325
I'll check it out tonight. Weird though, the guy I got it from said he just replaced the resevoir around 10k miles ago...
Old Apr 9, 2007 | 09:50 AM
preppy325's Avatar
preppy325
mb
I got a Havoline comparable one from a local auto parts store. I made sure with Mini that this would be ok.
Old Apr 9, 2007 | 10:22 AM
SRTech's Avatar
SRTech
The Havoline is orange so I guess you are correct that it is leaking. I don't think it's from that drain in the picture, though. It's probably just running down the back of the heatshields and dripping off the hose. Check the coolant connections connected to the tank, the tank and the cap. The caps leak if they are not really tight and some just leak.
Steve
Old Apr 9, 2007 | 12:02 PM
resmini's Avatar
resmini
Don't forget that when you check it cold the level will be lower than when you check it hot.
Have you been needing to add coolant?
When I got my MC the hose at the bottom of the overflow tank was leaking, tightened the hose clamp, problem fixed.
Old Apr 9, 2007 | 07:13 PM
preppy325's Avatar
preppy325
Well, I observed it today and I let it sit overnight and i didn't notice any leading on the ground. The resevoir tank is still where i left it yesterday, but the service engine soon light came on. Does anyone know how to pull the error code from the computer?
Old Apr 16, 2007 | 07:51 AM
preppy325's Avatar
preppy325
How come it's when the engine is cold it will be lower? I thought that when it is cool it is higher than when it's actually hot....Can you explain why the level is lower when cool vs hot?
Thanks!
Old Apr 20, 2007 | 09:43 AM
preppy325's Avatar
preppy325
Thanks!
I've been motoring it for the past 2 weeks and everything looks good. I think it was just low and when I changed the oil, I should have topped off the coolant....I just saved 208 bucks at least for diagnostic call.
Old Apr 20, 2007 | 11:00 AM
MiNi_MaC's Avatar
MiNi_MaC
How did you fix this probles? just changing the tank? for another OEM? i have this problem
Old Apr 20, 2007 | 11:32 AM
preppy325's Avatar
preppy325
is yours still under warranty? I wouldn't recommend getting the oem one. i think for some extra bucks there is a more reliable one. although that's all i've heard and haven't seen....
Old Apr 20, 2007 | 12:27 PM
MiNi_MaC's Avatar
MiNi_MaC
No it is not anymore. thanks!!
PhoR53
May 2, 2026 12:59 PM
navybsn
R55 :: Clubman Talk (2008+)
Dec 29, 2015 12:32 PM
freestylin599
Sep 9, 2015 09:00 PM
ShadyCoop
Aug 24, 2015 06:05 AM
pocketmaster
Aug 6, 2015 01:41 PM
