Drivetrain Losing Boost in high rev situations, possible DV leak?
Old Aug 31, 2015 | 12:07 PM
freestylin599's Avatar
freestylin599
So I'm running a 11' MCS on a custom tune running about 20 lbs of boost. I uprated the diverter valve with the Alta spring which was working fine for about 3 months(3k miles?). Right now the car scales up to boost, but when it gets up to about 5k it scales down to about 16 and i'll shift and regain 20lbs in the lower revs. Is this my DV just not keeping up even with the alta spring? or a possible leak somewhere else? Oroginally the car held 20lbs all the way up the rev range and im just not sure what would cause the loss of boost. No CELs or other problems with the car.
Old Aug 31, 2015 | 01:45 PM
Grizld700's Avatar
Grizld700
Who did your custom tune?
Old Aug 31, 2015 | 01:59 PM
freestylin599
Speedriven. I have a local installer/dealer.
Old Aug 31, 2015 | 02:05 PM
Grizld700's Avatar
Grizld700
Sounds like you have a boost leak somewhere. Have any work done recently?
Old Aug 31, 2015 | 02:08 PM
freestylin599
Not anything specifically with the vacumn or boost lines. I'm gonna have the lines double checked. I've just heard problems with the stock diverter being plastic so that was my first assumption
Old Aug 31, 2015 | 02:27 PM
Grizld700's Avatar
Grizld700
Usually the problem with the DV is the rubber diaphragm will get a tear in it and you wont be able to get much power beyond 4k. I changed my DV to the GFB DV+ to avoid that kind of issue.
Also, sometimes the intake manifold gaskets leak. Or if you have an oil catch can, that can be a source for vacuum leaks.
Old Sep 8, 2015 | 08:39 AM
freestylin599
Update on what's going on the car is still losing boost but now there is a clacking noise, like a shutter. Not sure if it's from DV but I think it is. Anyone know of any noises the DV can make?
Old Sep 9, 2015 | 09:00 PM
Systemlord's Avatar
Systemlord
Havent you checked the diverter valve yet? Until you actually check the DV we can't eliminate it as a possible cause, sometimes the spring gets stuck crooked inside the diverter valve and can cause boost leaks.
johntotah94
Oct 19, 2015 02:20 PM
theblackfalcon
Oct 11, 2015 09:49 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
Indimanic
Aug 19, 2015 11:08 AM
wind715
Aug 11, 2015 07:56 AM
