Sunroof problem closing
Old Mar 9, 2007 | 06:37 AM
2lange2's Avatar
2lange2
I have a pre-owned '03 S and my sunroof has an awful time closing. It makes a grinding noise and I have to help it close with my hand. When opening, it runs smooth and has no problems. Has anyone experienced with problem?
It is also quiet when closed and I'm on the road...
Old Mar 9, 2007 | 03:42 PM
lambspeed's Avatar
lambspeed
I have an 03 also. It does the exact same thing. I have lubed the tracks and tightened every bolt, but still alot of noise and chatter. So my plans... I will be cutting the roof off and installing a non sunroof, roof. Hardley ever use it anyway.
www.lambspeed.com
Old Mar 27, 2007 | 07:50 AM
coopermaniac's Avatar
coopermaniac
lambspeed why would u do that? why not jut leave ur sun roof closed and at least have a nice skyview.?? im confuzzled
Old Oct 2, 2007 | 09:20 AM
JPMM's Avatar
JPMM
have the same problem, did you find a fix?
Our sunroof developed the same sticky ,awful closing did you get the problem fixed?
Old Oct 3, 2007 | 05:39 PM
JPMM's Avatar
JPMM
Looks like a 6 hour round trip to the dealer!!!!
Old Oct 10, 2007 | 02:32 PM
MiniFen's Avatar
MiniFen
I had the same problem on my '03.......grinding noise and seemed slow. I took some white lithium grease and lubed up the rails and everything seems fine. I didn't put the grease where the old grease is visible, I lubed the rails above where I could see the old grease thinking that the old stuff had "run down" from where it was supposed to be (does that make sense?)
Old Oct 10, 2007 | 09:05 PM
JPMM's Avatar
JPMM
I couldn't figure out what to grease ,there seems to be a couple of rails on each side , I'll look again. I didn't want to slather a bunch and have it melt into the interior I did spray some oil to see if that would help and it did not so I thought it might be binding when the unit closes caused by a worn guide
Old Oct 11, 2007 | 10:31 AM
goldcountrymini's Avatar
goldcountrymini
I don't have this problem yet, but I hardly open the sunroof. I should probably re-grease as well.
Old Oct 12, 2007 | 05:03 AM
joedude99's Avatar
joedude99
Service Bulletin
There is a service bulletin on the noisy sunroof, and I had mine fixed under warranty just before it expired.
Old Oct 12, 2007 | 07:43 AM
MikeL's Avatar
MikeL
Mine had that problem. The tracks under the rubber strip needed to be lubricated.
Old Oct 18, 2007 | 07:23 AM
JPMM's Avatar
JPMM
Slathered grease all over and it helped alot ,ran the sroof open and closed and cleaned up the extra grease and its good to go !
WarEagle
R55 :: Clubman Talk (2008+)
May 3, 2019 03:00 AM
Toolman
Jan 20, 2016 06:50 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
HaveATank
Aug 24, 2015 10:26 AM
skippermini
Aug 13, 2015 06:13 AM
