Flat Tire Sensors and Aftermarket Wheels...
Old Aug 7, 2002 | 03:27 PM
wessieball's Avatar
wessieball
q
Old Aug 7, 2002 | 03:38 PM
dave's Avatar
dave
pug poo picker-upper
the Run-Flat pressure sensor is a relative comparison of the diameters of the four tires. Therefore, you shouldn't have a problem
Old Aug 7, 2002 | 04:27 PM
sjbartnik's Avatar
sjbartnik
The tire pressure sensor doesn't measure tire diameter. At least not directly.
The car has an ABS wheel speed sensor at each wheel. This is how it knows if a wheel is locking up so it can activate the ABS system.
MINI in their infinite cheapness...er, resourcefulness :smile: decided that they could make a ghetto tire pressure monitoring system out of this :smile:
It uses the ABS wheel speed sensors to measure the relative rotational speeds of each wheels. As long as each wheel has roughly the same rotational speed, it assumes all is well. If a tire goes flat, the wheel diameter decreases and the rotational speed increases relative to the other wheels, and this triggers the warning light.
So if you put 18s all around, you will be fine unless one goes flat :smile:
Old Aug 8, 2002 | 12:23 AM
Rocketboy_X's Avatar
Rocketboy_X
I woudn't call this cheapness or ghetto... granted, it's the cheaper of the two types of flat tire monitoring system, but the more expensive one requires sensors in/on the rims. It's just a matter of Passive vs Active monitoring.
Rocketboy_X
(PS. Scary thing is, is that the US Gov't is requiring all cars made after, oh 2005 I think, (maybe 2008) to have flat tire monitors. Thanks guys, I'll still be blinded by SUV's with ultra-bright headlights :evil: )
Old Aug 8, 2002 | 07:58 AM
sjbartnik's Avatar
sjbartnik
Yeah, I know. It was tongue-in-cheek. I think it's a clever way of providing the tire pressure monitoring capability without the added expense of pressure monitors. Good solution to keep costs down.
It won't work as accurately as a proper system but it works well enough.
Old Aug 11, 2002 | 03:42 PM
acetonic's Avatar
acetonic
Makes it much easier to change out the wheels however. And the flat sensors do work as I had the misfortune to discover.
Old Aug 13, 2002 | 07:35 AM
wainair's Avatar
wainair
Just reset the sensor when you put on the new wheels and it should work fine. Please post pics of your MINI once you get the 18's on it!
woodstudio
Mar 15, 2020 08:28 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
ltjpunk7
Sep 6, 2015 07:32 AM
TJANK
Aug 24, 2015 06:11 PM
