#1 Piston no compression, why??
Damn man... What happened with the blow out? I hope this wasnt the E55! I am just envisioning your super trick HRE's hitting the pavement at 80mph
It sounds like to me you need to come up to SB and take up drinkin' with me
Call me tomorrow.... Its Saturday! We can motor in the hills in my MINI then head down to the beach house for a couple whatevers.....
BTW... I ordered my Aero grills last night... Dont tell Nikki
Your going to have to help me with the install. I know you got the trick secret procedure...
Jasun
Your going to have to help me with the install. I know you got the trick secret procedure...Jasun
The 11 week project!!!!
Well I just got word that CP pistons are back ordered and I can't even order them till I find out how much the machine shop is going to have to bore out my motor. The car has been gone almost two weeks and it should be another two before the the boring is done and then another eight for the CP pistons to be made and shipped to Johnny's. I'm grateful my car is in good hands and that I have another car to drive around for work. So far the year has been tough in all issues of my life, I hope its not the a sign for the rest of the year.
Mario
Mario
If you would like your pistons a little faster let me know... i may have a way to pull some strings...
I have mine on order and will be here in 2 weeks. I guess it's all in who you know.
Bill
exactly... it takes less than two weeks to get them if you really want them and know the right people
I am not paying any extra fees to get them quickly either. 11 weeks to rebuild a car is ridiculous. I would seriously question what is going on in this instance. I wonder what the price is?
top secret huh... ohh wow... i love these projects... let me know how the turbo car comes along...
M
yup! it looks like early next week we might put something together.
lol... i believed i helped you handle your 04... and now i get the pleasure of ordering you a new 07!!!!!
no twin charge for you! Mike is running straight turbo right out of the box! hows that for most mods on the first day of ownership... lol...
I've got a piston compression problem too...
I'm new to what seems like a very old thread here, but I've recently discovered I'm losing compression in my pistons too. #4 is at 85lbs, and the rest are all lower than normal (around 170lbs). It's been driving similar to Mario's - grumbling and even stalling at idle, but fine at speed, if a little gutless.
I've got a 2003, not S, no mods (how boring, huh?). It's got 70k miles, but this seems like a strange problem to be having at this mileage with all normal servicing and 91 gas being used throughout its life.
The mini dealer (SF) is treating me very well. So far they've taken the head off and determined the problem is burnt out exhaust valves in the head. 8 of those need replacing, as well as the seats. They've said they can rebuild the head for $3500, or replace it for $5000. They are also waiting to hear from mini's area manager to see if they will help me out with the repair at all, since I'm no longer under a warranty.
Anyone have any idea how this might have happened? How your everyday, joe-schmoe owner could avoid this? Or is this possibly some manufacturing error that led to this? I haven't found any other threads on compression problems in minis, so this seems to be an isolated incident.
Any advice/wisdom is greatly appreciated.
At those prices they SHOULD treat you well.
The head can be repaired for a lot less, or for less than they are quoting but more than a repair you could upgrade to a ported/polished head and get some real performance gains.
Matt
Why cant he get a secondhand S head and put it on his Cooper?
p.s. Mario, sorry about your car, that SUCKS.
I dont know if I would say it's nobodys fault tho.... I would say it's EVERYBODYS fault.
You could buy a better aftremarket head for a lot less & make power at the same time. Unfortunately it sounds like the dealer is already through the door.
It's the gas. High EGT is the cause. Once the exhaust valve starts to degrade they go in a hurry. The cure is better gas or additives. Not knowing what's avilable in your area, RON or if 93 is available, so I can't say what exactly could be added. While everything is apart make sure to check the injectors are working to spec (bad gas can cause injector issues that will directly effect EGT)
Well, I just got some great news today. MINI is going to spring for rebuilding the head. Amazing. I'm 100% out of warranty, but they agree this is something that shouldn't be happening at my mileage. Go MINI. I still don't know exactly how to avoid this problem in the future, but I'll explore that, and also take a look at the fuel injector, just in case.
Thanks everyone for your help.
Mario, best of luck with yours.
-taffy
-taffy
-taffy
-taffy
No you don't need to use an additive with every tank of gas. 91 is all there is???? SOCAL gas is bad enough.
I've only heard of one or two stuck exhaust valves.
Congrats on the free head work!
Matt
-taffy
-taffy
