Please lube rear hatch hinges...
Old Dec 12, 2006 | 07:46 PM
joey1320's Avatar
joey1320
Hey guys just wanted to pass some info.
over the past 2 weeks i have seen a large number of MINI's coming in to the shop with the boot hinges broken in half or rusted at the pivot point, which then makes the boot open/close by bending the top.
As a precaution i have been lubricating the hinges on all the cars i have worked on. So if you have some time and a spraycan of lube, go outside and lube the hinges on the boot, believe me you will be glad when the boot works properlly, as opposed to fall off the car as it happened to a customer
Old Dec 12, 2006 | 10:37 PM
minirab's Avatar
minirab
Thanks for the info, will do it this weekend.
Old Dec 12, 2006 | 11:34 PM
retroom's Avatar
retroom
What do you recommend using on the hinges?
Old Dec 13, 2006 | 01:12 PM
joey1320's Avatar
joey1320
any kind of lube that won't damage the paint finish.
WD40
3M sillicone lube
as long as you are lubricating the hinges use whatever
Old Dec 13, 2006 | 03:42 PM
Yo'sDad's Avatar
Yo'sDad
Joey, I noticed no fittings on the regular door hinges. Any advice here. I was even thinking of drilling, tapping and installing a zerk. Would be very easy to do and a few shavings certainly would hurt anything on a door hinge. Maybe install zerks on the hatch hinges also./????
YD
Old Dec 13, 2006 | 03:58 PM
kenchan's Avatar
kenchan
i will check this out.
WD40... how about some lithium grease?
Old Dec 13, 2006 | 04:49 PM
Morris9982's Avatar
Morris9982
Now where did I put that can of bear grease...
Old Dec 13, 2006 | 05:04 PM
Fatherdeth's Avatar
Fatherdeth
I use White Lithium grease. Just wipe off the excess. Something else that works pretty decent, but you have to apply more often is graphite. Stuff works wonders and doesn't collect dirt.
Old Dec 13, 2006 | 07:15 PM
Crashton's Avatar
Crashton
Thanks for the tip Joey. It's great to have a MINI tech giving us real world info about our cars. Mine will be lubed tomorrow.
Old Dec 13, 2006 | 07:17 PM
Motor On's Avatar
Motor On
Thanks for the tip, I'll do an inspection next time I head out.
Old Dec 13, 2006 | 07:44 PM
UKSUV's Avatar
UKSUV
Ehhhh.........who needs hatch hinges.
Old Dec 13, 2006 | 08:41 PM
joey1320's Avatar
joey1320
cool see you then!
Old Dec 14, 2006 | 05:38 AM
Smokey's Avatar
Smokey
LPS 1 has always been my favorite greaseless lube or any version of Dry Film lube. You don't want to use anything that will attracted dirt and hold it, and we all know how the rear hatch attracts dirt.
Old Dec 14, 2006 | 07:06 AM
pberry51mini's Avatar
pberry51mini
No Fear Gear
Wouldn't it be great to have a regular (sticky?) thread that came from a Mini Tech and would alert us about issues they are seeing.
This is an invaluable service to all of us.
Thanks,
Paul
Old Dec 14, 2006 | 09:50 AM
shorn's Avatar
shorn
Semi-related boot note... Several times now the boot latch on my '02 MCS has froze in the unlocked/open position after the boot has been opened. Then when closing the boot does not latch - just bounces. To wake it up (I have not lubed it yet), I've had to thump the latch with my fist and that usually unsticks it. This thread reminds me to lube that as well as the hinges. I had already done the door hinges to correct the groan when closing.
Old Mar 16, 2007 | 08:29 PM
BG'sMC's Avatar
BG'sMC
Interesting to read this. I noticed on my 03 that the right side of the hatch was sticking out about 1/4" beyond the body. The Mini Service Tech told me the hinges had siezed a bit and bent. I quit using the hatch and watched the gap grow to about 1" without ever opening the hatch. Anyone ever seen this, or any ideas on what happened?
Old Mar 16, 2007 | 08:47 PM
erickvonzipper's Avatar
erickvonzipper
You don't want to use WD40 as a lubricant except in a 'lubrication emergency.' WD40 actually breaks up oil and grease and removes it (but not completely) from wherever it was before you sprayed the WD40 on it.
Zip
Old Mar 16, 2007 | 10:20 PM
TSR53's Avatar
TSR53
The proper lubricant to use is Würth HHS 2000. Goes on thin and slick as a penetrant, transfer properties evaporate and what is left over is a long lasting lubricant that is resistant. One important reason to use this is that you can get into the very tight hinge area with the thin spray wand. Yes, it might be tacky but if you keep this problem area clean it should be good to go. Used by professionals.
Old Mar 17, 2007 | 07:14 AM
joey1320's Avatar
joey1320
Zip
that's true but the hinges rust, so break the rust first with wd40 and then spary whatever kind of grease/antiseize you want to use.
Old Mar 17, 2007 | 08:14 AM
erickvonzipper
WD40 will not stop rust from occurring, nor remove it from a metal surface. That all has to be done the hard way. WD40 is good for freeing up rusty parts that are frozen together, (like nuts and bolts, and locked together hinges, I guess) although stuff like PB Blaster works better. If my hinges were so bad that they didn't work, I'd replace 'em.
Zip
Old Mar 17, 2007 | 09:54 AM
BigBrownDog's Avatar
BigBrownDog
I thought I read somewhere that there was a TSB or a recall related to the boot hinges - that the original design somehow trapped water and the replacements were designed differently...
Old Jun 23, 2007 | 01:00 PM
Mr.x.'s Avatar
Mr.x.
I just picked up new hinges from the dealer;
all indications show that they should be very easy to install
Old Jul 12, 2007 | 05:00 PM
h20baby's Avatar
h20baby
Just an FYI .............WD40 was developed by a firm for the U.S. MIlitary. The mission was to produce something that would repel water. Its main ingredient is FISH oil. The reason its called WD=Water Displacement.
The 40= it was the 40th iteration that produced a successful mixture which met the U.S. military requirements
Old Jul 12, 2007 | 06:19 PM
chpsk8's Avatar
chpsk8
You're pretty close... although the "main" ingredient is not fish oil...
http://en.wikipedia.org/wiki/Wd40
Its Stoddard Solvent...
http://en.wikipedia.org/wiki/Stoddard_solvent
Old Jul 12, 2007 | 08:03 PM
h20baby's Avatar
h20baby
Although it is unknown whether the formula contains fish oil, material safety data sheets for the product show that the main ingredient is Stoddard solvent, not fish oil.[2] WD-40 is, however, used by some sea fishermen as an added scent when fishing with bait.
