oil canister flat spot
Old Oct 6, 2006 | 11:31 PM
MiniKJ's Avatar
MiniKJ
Hi guys:
I have searched and seen the oil change how to thread. However, I can't find a post where someone mentioned there's a flat spot around the rim of the canister. If that faces up during reinstall, it will go on much eaiser. Could someone please help me locate that post? Thanks
Old Oct 7, 2006 | 06:08 AM
kenchan's Avatar
kenchan
actually it's on the threads.
Old Oct 7, 2006 | 08:21 AM
Crashton's Avatar
Crashton
Actually there are two flat spots 180 degrees from each other. Starting the canister back on with a flat spot to the top does seem to help it go on a bit easier. As kenchan said the flats are on the ring with the threads.
Old Oct 7, 2006 | 10:40 AM
caminifan's Avatar
caminifan
Another trick is to "pre-fit" the oil filter by pressing it onto the mounting post that it sits on. Just don't get too aggressive with the pre-fitting. Push the filter until you can feel it bottom-out.
Old Oct 7, 2006 | 10:45 AM
joey1320's Avatar
joey1320
the flat spots are on the threads as it was said, just make sure you coat the seal with oil or silicone lube so that way it slides better and doesn't get pinched.
after you do that reach with a towel and clean the housing, pour the 5qts of oil and run the engine and stick your hand back there and feel for any oil leaking from the housing.
have fun!
Old Oct 9, 2006 | 12:21 AM
MiniKJ's Avatar
MiniKJ
This is helpful. Thanks guys.
Kimolaoha
Jul 5, 2023 01:04 PM
woodstudio
Mar 15, 2020 08:28 AM
khumpert
Nov 30, 2015 11:48 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
