The Great Power Steering Pump Failure/Problems Thread
Old Jul 16, 2009 | 05:40 AM
  #301
buzzsaw's Avatar
buzzsaw
Here's a PS pump repalcement DIY write up that might help.
Old Jul 16, 2009 | 07:26 AM
  #302
Bigshot's Avatar
Bigshot
I noticed you are in Portland. Are you a member of the PDXMINI club?
If so, check with them as they have experience with replacing the pumps locally for a very decent price.
Old Jul 17, 2009 | 11:18 AM
  #303
tim781996's Avatar
tim781996
Apparently, this is a big problem. I can't drive my car right now because I need a new shaft and I was told by Autowerks of Freeport, Maine and MINI of Peabody that the part is on international back-order. Autwerks is waiting for three and MOP is waiting for seven. They should be arriving in August.
Old Jul 17, 2009 | 11:21 AM
  #304
tim781996's Avatar
tim781996
I'm having the same problem due to binding with the steering shaft. The part is on international back order. Driving the car right now would cause the pump to work very hard and it could burn it out, so the car is in my garage until the part is in.
Old Jul 17, 2009 | 11:26 AM
  #305
tim781996's Avatar
tim781996
I thought my pump was going, but it turns out it was the steering rack. With so many people having the same issue, a recall seems in order.
Old Jul 17, 2009 | 11:48 AM
  #306
tim781996's Avatar
tim781996
Just filed a complaint with the NHTSA. Seems like a common issue. https://www-odi.nhtsa.dot.gov/ivoq/Complaint.cfm
Old Jul 17, 2009 | 12:56 PM
  #307
Grassroots Garage's Avatar
Grassroots Garage
Tim, What parts do you need? feel free to call me 336-476-8551
--Dan
Old Jul 22, 2009 | 07:31 PM
  #308
dL_EVO's Avatar
dL_EVO
Powersteering going in and out randomly.
For the past 3 days, my powersteering has been going in and out randomly.
It will just go out randomly mid turn or at a stop light. It's getting pretty f**king annoying..
When it comes back, it just randomly comes back..
Anyone have this problem? I did do a search first, but most people either have power steering or do not.
Has something come loose and is blocking the flow of PS fluid therefore causing intermittent power steering?
Old Jul 22, 2009 | 07:35 PM
  #309
not-so-rednwhitecooper
I had this happen myself.
The terminals on the pump had corroded off and were hardly making contact. I ended up having to buy a new pump, the terminals are cast in plastic and aren't repairable.
Old Jul 22, 2009 | 09:29 PM
  #310
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
I'd say you need a new pump. We have em in stock. It's a pretty common problem.
http://www.waymotorworks.com/product...6&cat=0&page=2
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Jul 24, 2009 | 02:22 PM
  #311
Speed_is_Good's Avatar
Speed_is_Good
My car started doing this today driving to / from work.
What's the cost of this repair?
Old Jul 24, 2009 | 03:10 PM
  #312
tennis_man's Avatar
tennis_man
This is an expensive repair mainly because of the cost of the power steering pump. A new pump from a dealer is around $661 but can be purchased from other sources (like Ebay) for around $470 to $540. Rebuilt pumps are less and if you can wait for 7 to 10 days you can have your pump rebuilt for around $225 at BBA-reman.
The labor charge for installation varies depending upon if you use a dealer or an independent mechanic.
Old Jul 26, 2009 | 11:32 AM
  #313
ninjamini's Avatar
ninjamini
Power steering failure - Cost?
My power steering pump has failed. After 5-10 minutes of driving I loose all power steering and its impossible to turn. How much is the part and where is a good place to get it?
Old Jul 26, 2009 | 05:53 PM
  #314
tennis_man's Avatar
tennis_man
See this thread: https://www.northamericanmotoring.co...ml#post2829985
Old Jul 26, 2009 | 06:28 PM
  #315
katanabob's Avatar
katanabob
I just dealt with this on my '02 MCS.
BBA reman was $215, not including shipping to them. Quick turnaround, but they'll also send you one and wait for your core if you're so inclined.
Removal/Reinstall was covered pretty well in a few other threads; what's important is that though it was a huge pain in the rear, it was do-able. If you're so inclined, here are my tips to getting it done:
1. I don't see how you could accomplish this project without ramps or a lift. Maybe you could do it on jackstands, but they'd have to be pretty tall.
2. There's a lot of stuff to disconnect, and it's all on the top of the pump. Nearly everything will have to be disconnected and reattached with the pump hanging in the 'almost-out' position.
3. There's a thread somewhere that details using a Dremel tool to notch out the slot that one of the bolts fits through. This is wholly unnecessary if you look at the pump and remember that there are three axes to rotate around. Square peg, round hole.
4. Tupperware or plastic container to catch fluid (and another hand to hold it in place while you disconnect things) is a must.
5. Glossy magazines under tires for the post-install air-bubble eradication are also a must.
It took me an hour to get mine out and only a half to get it back in. Having small, nimble hands helps, too.
-c
Old Jul 27, 2009 | 09:11 AM
  #316
istara's Avatar
istara
Just an FYI on BBA-reman: if you want to get a working pump before sending in the core, they charge $200 dollars difference. So,
$220 + shipping there for yours to be rebuilt
$420 + shipping there to get someone else's rebuilt unit and turn in your core
$570 + shipping there if you get a rebuilt unit and don't send back your core.
I called them today and they have 2 in stock. Since I can't justify $200 more for the same end, however, I'll be rigging my mini to run without power steering until they can fix mine own.
Old Jul 27, 2009 | 09:42 AM
  #317
dL_EVO's Avatar
dL_EVO
This appears to be a well documented problem with the 1st gen Mini Coopers.
Will the dealer cover this even if your out of warranty? I know sometimes dealers will cover something out of warranty if it is a very common problem.
Old Jul 27, 2009 | 11:27 AM
  #318
buzzsaw's Avatar
buzzsaw
What will you do to rig your Mini to run without PS?
Old Jul 27, 2009 | 11:37 PM
  #319
Some Guy's Avatar
Some Guy
Doubtful that the dealer will help.
Old Jul 28, 2009 | 05:33 AM
  #320
Vendor
Caution on the rebulit pumps. I already replaced one of the "rebuilt" units. It failed a month after getting it rebuilt. Buy new and be safe.
Old Jul 28, 2009 | 08:06 AM
  #321
dL_EVO's Avatar
dL_EVO
******! I was going to buy rebuilt too..
The Mini Cooper is really tapping into my EVO modding funds..
I need a new windshield, new PS pump. and possibly new AC compressor.
Old Jul 28, 2009 | 08:30 AM
  #322
Bigshot's Avatar
Bigshot
Another option is to see if there is a local shop that has a service/parts account at a MINI dealer. You can then get the redisigned/updated unit for not much more.
Old Jul 28, 2009 | 09:07 PM
  #323
Some Guy's Avatar
Some Guy
Off the BBA website: "[FONT=Arial, Helvetica, sans-serif][SIZE=1]All BBA products are covered by a limited 2 years warranty. See your invoice for terms and conditions."[/SIZE][/FONT]
Old Jul 28, 2009 | 09:17 PM
  #324
Some Guy's Avatar
Some Guy
+1
Old Jul 28, 2009 | 10:00 PM
  #325
ninjamini's Avatar
ninjamini
So I can buy one for $600
Rebuild the one I have for $250 and wait 3-5 daysfor its return and not drive the car.
or $250 and drive the car with out a powersterring pump.
All lousey answers.
