wiper fluid residue
Old Mar 31, 2006 | 02:12 PM
Louispup's Avatar
Louispup
wiper fluid residue
My MC was already in the states when they put my name on it, (thank God).
Anyway, it has the cold weather package which I accepted gratefully rather than wait for a build your own. I like the heated (sport) seats.
The rear wiper/washer jet however, leaves an awful residue on the paint and trim. Is this a common problem? Can I reduce the problem by diluting the fluid? How can I reduce the problem if at all? Thanks in advance for any helpful info.
Old Mar 31, 2006 | 02:15 PM
daemon2's Avatar
daemon2
Try a different fluid. If you dilute with water you run the risk of freezing and cracking lines/coolant container.
There are a variety of fluids on the market.
Old Mar 31, 2006 | 05:58 PM
PKMINI05's Avatar
PKMINI05
I had this problem too. I had to wax and buff out the stain. I've changed wiper solutions and the problem is gone.
Old Mar 31, 2006 | 07:02 PM
Goose's Avatar
Goose
I had a similar (if not the same) problem. Here's a link to my old thread. If nothing else, you're not alone.
https://www.northamericanmotoring.co...ad.php?t=46721
Old Mar 31, 2006 | 09:38 PM
AZMCS's Avatar
AZMCS
Had it too with OEM fluid. Now I use some Pepboys solution that seems to have fixed the problem. Other option is just let it run empty. Of course if you actually use the rear wiper this is not the best idea!
Old Apr 1, 2006 | 07:54 PM
Louispup's Avatar
Louispup
Lots of, erm, solutions. thanks for the Info!
Old Jul 17, 2006 | 09:22 AM
acitydweller's Avatar
acitydweller
Drain the fluid in the system, fill with water, drain again, and replace with yoru favorite wiper fluid.
Be sure to drain the rear wiper fluid and headlamp washers as well
Scm68
Jan 27, 2016 12:33 PM
vulkandino
Oct 31, 2015 08:29 PM
schr5530
Oct 1, 2015 05:11 PM
Samhillrocks
Sep 29, 2015 12:55 PM
silence2-38554
Sep 28, 2015 12:19 PM
