Need help setting the Clock ACCURATELY
Hi
I have an 05 MCS. Setting the clock accurately is nearly impossible it seems to me
. The manual says that the clock will return to normal operation after setting it in approximately one minute. In my experience, this "return to normal" time period is really variable and prevents an accurate setting.
Am I reading this wrong? Is there a trick to getting the clock to be truly accurate to the second? I want the time to be "right on" not +/- a minute or two.
. The manual says that the clock will return to normal operation after setting it in approximately one minute. In my experience, this "return to normal" time period is really variable and prevents an accurate setting.Am I reading this wrong? Is there a trick to getting the clock to be truly accurate to the second? I want the time to be "right on" not +/- a minute or two.
Good luck. I know there is an issue with the 05 clocks running fast. I believe there was a tech bulletin about this, and it requires changing the whole speedo to fix. Mine is doing this, but I am holding off until my 10k appt to get it done(along with a list of about 10 other little things!)
Even if you can set the time accurately to the second, you won't be able to depend on it to hold its accuracy. On every car I have ever owned, the clock has always drifted to varying degrees. And this will date me, but I was a child, you could count on the car clock to stop functioning altogether after a couple of years.
My clock just can't stay accurate either
I've read the Bulletin on the clock running fast... and if mine were doing that, I'd take it right in for warranty support. However, my clock seems to run 2 minutes SLOW no matter what I do
I've even tried setting it 2 minutes FAST, and within about 5-10 minutes, it's slow by 2 again
One thing I did notice was that the ":" for seconds blinks a bit after I set it, but then eventually stops
Any idea which is the normal operation? Blinking to indicate seconds, or steady?
Thx
Any idea which is the normal operation? Blinking to indicate seconds, or steady?Thx
Let me try again. I don't have a problem with the clock running fast (which is a known problem with a known fix). My clock keeps good time, I just can't set it accurately. Does anyone know how to get around the delay associated with exiting the "time set" mode and returning to "normal mode?"
how easily will they change out to spedo for the problem. my clock starts running fast the day after I set it, it gets to 10 mins. fast rather quickly. I was planning on trying to get it done with my 10k service - do I just need to tell them the problem and that i want it fixed? Will they automatically do it?
good to know...but the clock is the only thing about my MINI that really bugs me. I've got the fast clock problem. The service department replaced the whole unit per the tech note instructions and the new unit has the same problem. (and in the process I now have some nice scratch marks on my dash from the de-installation/installation)
I had mine changed out 2-3 weeks ago and it is working 100% perfectly now.
Originally Posted by chows4us
"A man with two watches never knows what time it is"
Anon.
Anon.
Fast Clock issue
I'm interested to hear there is a bulletin on the problem of fast clocks - I have an 06 Cooper and just had to set it back 10 minutes, which it gained in about a month of driving.
How do I get a copy of the Bulletin? Will the dealer know about it?
E. G. B.
E. G. B.
E. G. B.
E. G. B.
I
OutMotoring
Sep 8, 2015 06:27 AM
