need help with a boost gauge
Yes, just plug it with the fuel pressure regulator hose. (long red one on the drawing).
Just unplug it from under the intercooler, and get som extra hose from your local auto store. Your boost gauge should come with the "T" fitting.
It's an easy job to do with the intercooler removed. Just take your time to get the hose through the firewall. There's a "hole" near the steering column, but you'll probably need to make a hole in it, with a small screwdriver.
awesome, thanks for the help. I'm going to mount the gauge to the left of the tach with a 2 1/16 mounting cup, so do I need to break out the hacksaw and trim these threads down? It doesn't fit all the way into the cup as is now:
and with that clear tubing, how does it seal into the the sealing adapter? Does it just hold itself in there? I'm not sure if I just need to feed the tube into the adapter and let it hold itself in there. I'm not too clear on the directions.
and which grommet do i use for the back of the gauge? the smaller one that came with the gauge or the bigger one that came with the mounting cup? DarkMiniCooperS, I'm using your setup on your webpage as my inspiration So any other pointers/help you can give would be much appreciated.
Also, did you need a bigger screw on the back of the tach to get the gauge to attach there? I haven't looked at it so I'm not sure how long the threading is.
okay, there's a piece that flares in the middle i believe...autometer calls it the "ferrule" I think? Is this what you're mentioning?
I thought about mounting it right there, I just have too many anxieties about drilling into the a pillar.
Thanks for all the replies, very very helpful.
I'll try just snipping the thread with wire cutters.
I may just wind some electrical tape around the end of the tube that attaches at the "tee" fitting, just to be safe.
One question - what did you do with your wiring? did you wrap it with wire loom or something? (where it comes out of the back of the gauge?
Err...one more... - where did both of you run your wiring for the lights? I've got a few feet of extra wire I can use, as I'm assuming I'll need it...If anyone could post some directions on that and/or pictures of where to tap into wires.
i used a grey/red wire from under the dash next to the fusebox. grey/red wires ae all for interior gauge lighting.
you will not need the other mouting bracket, thats for mounting in a hole.
you will probably need more rubber hose to go from the t fitting to the other lines but i wouldnt try and add more nylon tube. i ran rubber tube from my firewall to the adapter.
I'm not sure I understand that last part. I'm going to the parts store in a little while, I need to know what all I need to buy. what size rubber hose? how much of it? do you mean you bought more hose to go from the tee to the firewall? or from the firewall to the adapter on the back of the gauge?
Boost gauge install
The T and the vacuum hose you will need is 5/32.
Read this, you won't have any questions afterwards
https://www.northamericanmotoring.co...ht=boost+gauge
While your in there do the VGS Mod, it's nice
Originally Posted by Bahamabart
Aren't you going to intefere with the side air bag? Wouldn't it be in a better line of sight next to the tach?
THERE IS NO AIRBAG THERE!!!!!
the strap that hold the airbag to the pillar is there, the cover only pops open and foesnt come off.
