Oil breather? Line from valves to intake??
Old Oct 12, 2005 | 12:20 PM
Kentiki's Avatar
Kentiki
I've seen this discussed in relation to a DIY HAI, but couldn't find the thread. Anway, there's a hose that runs from the right side of the valve cover area into the intake hose. What the heck is it?:impatient
I think the thread in question had the line taken off, and replaced with an oil breather/filter. Can this harm anything?? Why's it even attached to the intake at all? Is it just an emissions issue? I ask cuz I'm thinking of a DIY CAI, and don't want to have to bother with this line.
Thanks for any info!
Ken
Old Oct 12, 2005 | 01:56 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
That hose is the breather inlet for the crankcase. Many have simply attached a small breather filter to this with success. The only issue that might crop up is occasionally having an oily smell coming from the engine during low vacuum/boost conditions because the PCV system is not functioning under these operating conditions and any blow-by that might be hapening reverses and comes out via the beather inlet. For most people, this is not an issue. Attaching a filter prevents debris from entering the crankcase during normal operation.
Depending on emissions laws and testing in your area, disconnecting the breather and/or fitting it with an external breather might fail a visual inspection. If you are using a filter with an extended neck, in some cases you can fit a hose nipple there to accomodate the breather hose.
Old Oct 13, 2005 | 07:53 AM
Kentiki's Avatar
Kentiki
Cool! Thanks very much for the info. I'm gonna try it out. I've learned more on NAM in the past year or so than I can mention.
Ken
Kimolaoha
Jul 5, 2023 01:04 PM
bobbiemartin
Jan 20, 2016 05:28 PM
PelicanParts.com
Aug 14, 2015 11:07 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
