xenon problems
Old Sep 18, 2005 | 11:22 PM
meanboy's Avatar
meanboy
xenon problems
My xenons turned off and then came back on three times today. But after the last time it was fine. Anyone ever had that problem?
Old Sep 18, 2005 | 11:30 PM
vm's Avatar
vm
Problably it's the light bulb, they don't work well when the gas is low. Have you seen them on? do they look yellowish?
Old Sep 18, 2005 | 11:34 PM
meanboy's Avatar
meanboy
They look normal when they are lit, they just both turned off without warning.
Old Sep 18, 2005 | 11:46 PM
vm's Avatar
vm
didn't notice you said they turned off, my bad . You better check the balasts (?). The xenons lit's when the gas is hot enough.
Old Sep 19, 2005 | 12:23 AM
meanboy's Avatar
meanboy
I better check something that's for sure! I'll see if the problem continues. I don't drive it at night all that often though.
Old Sep 19, 2005 | 09:51 AM
BMDoubleU's Avatar
BMDoubleU
indeed.. :smile: you get them checked out as soon as possible... we pay alot for our cars.. so, we should expect alot of satisfaction..(:smile: no problems)
Old Sep 19, 2005 | 09:56 AM
meanboy's Avatar
meanboy
I drove it this morning with the lights on and whenever I was behind someone I looked for the headlights. They seemed to be on...
Old Sep 19, 2005 | 11:13 AM
Moneypenny's Avatar
Moneypenny
I don't know about the headlight version, but the Xenons I work with, when they get up in hours it may take several strikes before staying on, as a result they need to be changed or the amperage needs to be bumped up.
When they went on/off those three times, how far apart were the......contractions? i.e. several seconds or several minutes? If they're like the ones I work with and it was seconds, it's just trying to strike, several minutes, there's a problem.
Hope it helps, but regardless I would take it in and let 'em know what's going on.
-Sarah
Old Sep 19, 2005 | 11:20 AM
meanboy's Avatar
meanboy
It started about five minutes after I started driving it. The contraction happened all with two minutes and then ceased. The headlights operated normally after that. I drove for another 1/2 hour without incident.
Oh, and it flicked off and on. And the last two times it did it I manually turned them off and then turned them back on. The car has 13k on it and majority of it during the daytime.
Old Sep 19, 2005 | 02:41 PM
vm's Avatar
vm
-Sarah
Does this happen with just one bulb, or both? Mine does with one, but are the bulbs (they are old). It's time to get a good Hella kit
Old Sep 19, 2005 | 03:15 PM
meanboy's Avatar
meanboy
Both sides...they just shut off and then my daylight running lights came on.
Really weird.
Old Sep 19, 2005 | 04:48 PM
Moneypenny's Avatar
Moneypenny
Strange, I would get it looked at....
Old Sep 19, 2005 | 05:04 PM
meanboy's Avatar
meanboy
If it continues to happen then I will. I have no service/repair issues, except for rattles at this moment.
edit: drove around tonight for an hour and no issues
Old Sep 20, 2005 | 01:48 PM
vm's Avatar
vm
I have you a bad new. I recently talk with a friend of mine an told me could be a shortcircuit, or (hope so) the battery. Another thing he told me is that the philips bulb is one of the worst. I'm going to change them next week, but not for hella.
Old Sep 20, 2005 | 02:00 PM
meanboy's Avatar
meanboy
Maybe, it's just a bad bulb. I think mine is different then yours in a sense that both go out and the driving lights go on. It's like the switch or something is acting up.
minimofo
Nov 16, 2016 05:56 AM
oeklm
Feb 17, 2016 01:00 PM
Rai1gun
R60/R61 Stock Problems/Issues
Jan 11, 2016 05:52 AM
