"check engine" icon light.... (SES)
Old 05-18-2005, 07:27 AM
eddiboyii's Avatar
eddiboyii
eddiboyii is offline
"check engine" icon light.... (SES) fuse location
ey guys, i just want to know if when you turn on the ignition but not start it, will this icon above the EML light should turn on? all the indicator lights seemed to turn on like the eml, airbag, brakes, runflat indicator, etc etc... and after a while it will go off... it's just that engine icon won't light... is that normal??? i've already tried to remove the fuse, the EML light won't turn on... (do they share the same fuse?) and the fuse is fine...
need help.... i'm a bit worried....
-->ed
Old 05-18-2005, 08:14 AM
C4's Avatar
C4
C4 is offline
-->ed
Which model do you have?
Cooper or Cooper S? Automatic or manual??
Old 05-18-2005, 08:18 AM
eddiboyii's Avatar
eddiboyii
2003 mini cooper S speedometer on the center.. no nav...
Old 05-20-2005, 07:45 PM
gone_motoring's Avatar
gone_motoring
gone_motoring is offline
On my '04 the light immediately above the EML is the DSC light I believe. It seems that the sequence of lights varies on sucessive "On" cycles. Occasionally the DSC light will light when the key is turned on, other times only the battery and oil pressure light come on. Likewise, sometimes I notice the airbag and ABS lights, other times they don't come on either. Might also have to do with how far off or on you turn the key.
Old 05-21-2005, 06:35 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
andy@ross-tech.com is offline
The Service Engine Soon lamp should definitely come on when you turn the key ON but don't start the car. That's the self-test showing that the DME is functioning and connected. Disconnect the DME, turn the key on, and you'll find the light does not come on.
Old 05-21-2005, 06:53 AM
gone_motoring
But is that the light he's asking about- isn't the SES light on the tach....or is it on the speedo above the EML in '03s?
Old 05-21-2005, 09:21 PM
eddiboyii's Avatar
eddiboyii
oh i see... where can i find the DME? or anyone of you knows whre the fuse for the check engine light is located?
Casrio
04-20-2021 01:52 AM
rtk90
08-29-2019 09:08 AM
CardinalsRule
06-11-2016 04:34 PM
M7Speed
R58 :: Coupé Talk (2012+)
09-03-2015 07:29 AM
M7Speed
09-03-2015 07:27 AM
Quick Reply: "check engine" icon light.... (SES)
