Reset oil counter
Old Sep 6, 2008 | 06:54 PM
  #26
jollyroger927's Avatar
jollyroger927
Sorry to bring this thread back but i tried these method and i think endded up resetting the inspection instead of the oil change i think? it says 15000 and inspection when i turn the key now. not oil change. just wondering if someone could help me out.
Old Sep 8, 2008 | 05:58 PM
  #27
hotchilimini's Avatar
hotchilimini
Done the reset and got the same results with the "oil" counter changing to "service". Wondering if I done procedure correctly.
Old Sep 22, 2008 | 12:17 PM
  #28
MINI-IZED's Avatar
MINI-IZED
The MINI has different service intervals. Example: It goes OIL CHANGE, INSPECTION I, OIL CHANGE, INSPECTION II. I am assuming that when a reset is done, it moves to the next interval. If I was to reset after the second oil change, I believe it is going to show INSPECTION II next. This is an assumption on my part, can anyone confirm this?
Old Sep 22, 2008 | 03:01 PM
  #29
jollyroger927
I think you are right. I changed once and it went from Oil Change to Inspection. Should rotate.
Old Dec 27, 2008 | 01:47 PM
  #30
LMM's Avatar
LMM
Just did my oil change per the sticky and it worked well although I think I was a little impatient taking the canister out and dripped a little oil. Then I reset as per post #2 and it worked like a charm.
Thanks everyone!
LMM
04 MCS
06 Louts Elise
woodstudio
Mar 15, 2020 08:28 AM
portedbuckle
Sep 11, 2015 07:02 AM
Didicus71
Aug 28, 2015 02:00 PM
Aug 25, 2015 09:18 AM
AoxoMoxoA
Aug 21, 2015 09:15 AM
