Oil Temp Gauge Not Working
Old Mar 25, 2005 | 10:23 AM
770 KOF's Avatar
770 KOF
I have the MC40 edition and my oil temperature gauge has quit showing any reading for the last month or so. It was reading 100C (after warm up) during last autumn and I put it down to the cold weather but it doesn't even get off the stop. Recently it did briefly jump up to 80C and then went back to the stop. Maybe a loose connection at the sensor? Anyone know where to look as I'm not due for a service anytime soon and don't want to put it in to the dealer just for this.
Old Mar 25, 2005 | 10:41 AM
RedBaronF2001's Avatar
RedBaronF2001
Look under your engine and see if the wire came unplugged from the oil drain sensor.
Old Mar 25, 2005 | 05:54 PM
ScottinBend's Avatar
ScottinBend
The sensor is located in the oil pan drain plug. Check the connection.
Old Mar 29, 2005 | 06:32 AM
770 KOF's Avatar
770 KOF
Thanks I will check it out this weekend. You know what - I seem to remember that this problem started just after I had a 5,000 mile oil change. Could the mechanic have dislodged the wire when he removed the drain plug or not put it back on correctly?
Old Apr 8, 2005 | 06:01 AM
lsd05jcw's Avatar
lsd05jcw
question on sensor plug location..
Hi: I changed my oil recently (have the chrono pack) and didn't see the oil pressure/temp sending units.... the plug appeared as my 2004 model year did without chrono pack... any help folks??
thanks!
Old Nov 1, 2020 | 01:10 PM
Roamer2003's Avatar
Roamer2003
My 2003 S had an intermittent problem with the optional oil temp gauge, sometimes the needle would peg all the way to the right, past the max 150 Centigrade point. Dealer replaced the sending sensor (in the oil drain plug). But that didn't help. So I removed the old oil temp gauge and replaced with a new one from Summit Racing - part number VDO-310012. The new one is Fahrenheit instead of Centigrade, which is better for me and seems to be working correctly now. The new one had a white back light - so I used the light from the old unit so that it matched the rest of the gauges.
Old Nov 9, 2020 | 01:46 PM
Yep this is the sensor which is now nla below. We have been working with VDO and should have some gauges in the future, they will not have the MINI logo but have some options. https://www.ecstuning.com/b-vdo-parts/v-mini/
https://www.northamericanmotoring.co...mp-sensor.html
polepino
Jun 26, 2016 11:13 AM
knipdlo
Jul 22, 2008 01:57 PM
kriation
15
May 17, 2008 09:41 AM
TonyB
Sep 11, 2006 04:28 PM
