Can’t Solve Misfire Issue
Old Dec 23, 2024 | 06:20 PM
Etmil35's Avatar
Etmil35
2008 S. I’m tearing my hair out. I have lumpy running and the engine bogs after revving. The only codes I have are misfires on all four cylinders. The car has a lot of new parts. New HPFP, timing chain, water pump, thermostat, new injectors, spark plugs, coils, oxygen sensors, vanos solenoid. Any suggestions?
Old Dec 24, 2024 | 09:29 AM
Unmetered air coming in? Crack in intake manifold?
https://www.northamericanmotoring.co...ody-codes.html
Main wire harness ground loose?
https://www.northamericanmotoring.co...lve-cover.html
R56 Car not starting after changing valve cover - North American Motoring
Old Dec 24, 2024 | 09:43 AM
Etmil35's Avatar
Etmil35
Thanks ECS. I’ll check the ground. I had smoke tested the car a couple of months ago, but I will have to try that again. Where the best place to connect for a good smoke test?
Old Dec 26, 2024 | 07:26 AM
Hello, intake port locations.
https://www.northamericanmotoring.co...leaks-r56.html
rob71charger
Jun 7, 2024 04:36 PM
shaunmac9128
May 20, 2019 01:25 AM
SlothsRUs
May 1, 2019 04:34 PM
kurtsunn
Apr 18, 2018 05:44 AM
Cantbuytime
Jun 2, 2017 01:26 PM
